Fuel gauge not working properly
2005 TOYOTA SIENNA
105,600 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
The amber light is on for gas fill up but my digital reading says it has 20+ miles left before filling up.
Is the digital reading correct?
Apr 1, 2020 at 10:03 AM
  • CAR REPAIR CONTRIBUTOR
The digital reading in the cluster? If this is what you are referring too, this is simply a calculation and is generally accurate. However, I would not take it down to the mile because it could leave you stranded. Most of these gauges will not display a mileage once it is under a certain limit. Most are around 20-30 miles to empty.
Again, this is just a calculation based on the current driving conditions. So for example if you are at 20 miles to empty and then start accelerating aggressively you will not make it 20 miles. If you drive very lighted footed you may make it more then 20 miles.
Let me know if this answers your questions. Thanks
Apr 1, 2020 at 3:52 PM
