Mechanics
FRONT, DRIVER-SIDE WINDOW NOT FUNCTIONING UP NOR DOWN.
2003 Toyota Camry • 152,000 miles
The front driver-side window will not move up nor down via the electronic switch on the door inside panel. All of the other windows function properly. I believe the issue is with the electric motor that functions the windows. Please help.
JoeMan34
May 12, 2013.
Maybe right or could be switch do you have a meter or test light?
Docfixit
May 12, 2013.
No, nothing out of the ordinary is 'on-display' if that is what you are asking. Could it be some kind of fuse problem? If not a fuse problem, I bet it has something to do with the wiring / overall wellness of the electric motor that runs those switches. Any more suggestions?
AD
JoeMan34
May 13, 2013.
Need to check for voltage at switch if present then operate switch check for voltage to motor if present then motor faulty
Docfixit
May 13, 2013.
AD
