Car cranks but wont start
SHEETS26
  • 25 POSTS
Where is the condenser located at? Also the fuel pump is working before but now you cant hear it could we have blown it messing with fuses. Also when we put bigger fuse in it started but cut out could it just need bigger fuse to run on? But when u tak ethe relay out the fusr dosent blow and if the relay in and the shut off switch is out then it dont blow. Any suggestions
Sunday, May 21st, 2006 AT 2:42 PM
LOSONE
  • 1,616 POSTS
The very worst thing you can do is to put in a larger fuse. It heats the wires and they melt together and you will have a mess.
Like I said in an earlier post disconnect the fuel pump and see if it blows a fuse.
The condenser is part of the A/C system and is in front of the radiator.
Sunday, May 21st, 2006 AT 6:06 PM
SHEETS26
  • 25 POSTS
Do you have to pull the pump to do that?
Monday, May 22nd, 2006 AT 4:56 PM
