Ford Windstar Repair Question
Topics covered: Abs, Brake lights, Brakes.
Asked on November 5, 2007
ABS Lights
I have a 2002 Windstar that keeps poping up with the ABS and Brake lights what can this be? Could it be the proportioning valve? We have replaced all the brakes also replaced the calipers and it still pops up with the ABS and brake light.
What do I do?
Sabrina
What do I do?
Sabrina
Answer
Replied on November 5, 2007
Abs system is different than the brake system
For the abs system you need to scan the van for codes
Possible sensor out on one of the wheels
Or if you check the ring gear for crack
Get the codes that should pin point the trouble area
Also check the float in the master cylinder ( it may be stuck at the bottom)
Make sure master cylinder full with fluid
Give it a good tap or two
Good luck
