Mechanics
TRANSMISSION RANGE SENSOR
2000 Ford Windstar
Transmission problem
2000 Ford Windstar 6 cyl Two Wheel Drive Automatic 135000 miles
Check engine light is on. O/D flashes on startup until moving in the car. Checked OBD-II code and it shows:
" P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)"
Should I replace this sensor or the components off it. If I do replace the sensor will I need ANY special tools to put the new one on?
Thank you - Scott
Scott77
April 26, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
