1996 Ford Thunderbird Repair Question
Topics covered: Brake lights, Brake light bulb, Brake light switch.
Asked on January 2, 2009
1996 Ford Thunderbird No Brake Lights
Brakes problem
1996 Ford Thunderbird 6 cyl Front Wheel Drive Automatic 158,00 miles
I have a 1996 Ford Thunderbird. I have a problem with my brake lights. I only have rear brake lights when I press on the brake pad hard. Light or moderate pressure of brake pad will produce no brake lighting whatsover. I've checked all fuses and brake light bulbs. Can anyone suggest what may be causing this condition. A possible switch problem somewhere? Any help would be appreciated.
Thanks
R. Fannon
Thanks
R. Fannon
Answer
Replied on January 2, 2009
you probably need to adjust or replace the brake light switch.
it's under the dash above the brake pedal
