Follow the upper radiator how to the engine there is will be under the housing,
1. Drain coolant level below upper radiator hose and thermostat housing.
2. Disconnect upper radiator hose at thermostat housing, then remove two thermostat housing retaining bolts.
3. Remove O-ring seal and thermostat from intake manifold. Inspect O-ring for damage and replace if necessary.
4. Reverse procedure to install. Tighten bolts to 15-22 ft lb.
SPONSORED LINKS
Sunday, October 19th, 2008 AT 9:04 AM
