1987 Ford Thunderbird Repair Question
Topics covered: Fuel pump, Engine, Engine performance.
Asked on March 19, 2008
Fuel pump
Engine Performance problem
1987 Ford Thunderbird 4 cyl Wheel Drive Type unknown Automatic 200000 miles
I have a 1987 Ford Thunderbird Turbo Coupe 4 cyl. The fuel pump keeps burning out. Any suggestions as to the cause of this? I have been told that the ECM needs to be replaced.
Answer
Replied on March 27, 2008
first see if you have the proper fuse in for the fuel pump, also check the relay.
if those are good check for a grounding wire or it could be a bad ECM.
