1993 Ford Telstar Repair Question
Asked on June 6, 2010
Engine shut down when a/c fanspeed at lev
Air Conditioning problem
1993 Ford Telstar 6 cyl Two Wheel Drive Manual 120000 miles
The engine runs fine when the A/C fan speed slider is at 1 and 2. You can rev the engine by pressing on the accelerator. When the fan speed slider is at 3 or 4, the engine, at idle speed, runs fine. However, the accelerator is pressed. the engine shuts down with the rpm diving to zero.
Can you help to identify the problem?
