Engine is hard starting?
1997 FORD TAURUS
BROKERSWAP
155k- car has trouble starting in the morning, once it starts it runs good - it's easy to start when warm?
Jun 28, 2007 at 10:51 AM
98RANGERXLT
  • CAR REPAIR CONTRIBUTOR
  • 301 POSTS
This sounds like a weak fuel pump but to be sure lets run down these guides to see if we can fix it
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
and
Jun 28, 2007 at 7:55 PM
BROKERSWAP
3.0 litre 24-valve, auto.- check engine lite on for last 70k miles- Cleaned out ther plenum with carb cleamer and fixed 2 vacuum leaks, so the car idles better
Jun 29, 2007 at 10:01 AM
HARLEYRYDER
  • 6 POSTS
when i start thr car it takes too long to start ..after starting it runs perfect .
Oct 25, 2020 at 11:27 AM (Merged)
  • 110,190 POSTS
Hi:
What you need to do is check for fuel pump pressure drop off. When you turn the key on, there should be pressure. WHen you shut the key, it should hold pressure for some time. WHat you need is check for fuel pressure drop off when you first shut the key. IF it drops off right away, that is why it takes time to repressurize the system and longer to start.
Here is a how to for checking fuel pump pressure and drop off. Check it and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 25, 2020 at 11:28 AM (Merged)
JAS_22
engine will not start unless accelerator pedal is pressed to the floor. when engine starts it has no power or acceleration and catalytic converter turns red and gets hot enough to catch on fife. Fuel pressure is at 35psi.
BMRFIXIT
  • 19,053 POSTS
Check firing order ,make sure its firing on all cylinders
check for excessive fuel in cylinder and on plugs
check fuel pressure regulator
remove O2 sensor before catalytic converter and check exhaust back pressure
if high suspect clogged catalytic converter
RAY.TAYLOR
Starts and runs fine when engine is cold. After is warms up it cranks about three times longer then when cold. After it starts runs rough for about 15 seconds than smoothes out. Do not notice any problems when driving
SERVICE WRITER
  • 9,123 POSTS
This is something that is going to require some troubleshooting to find the cause. When the problem happens is when it can be tested. I suggest making an appointment with a shop you are comfortable with to do the testing. Set up an appointment so that when you show up, the problem will be present and the diagnosis can be done. Make it clear that when you get there you want it checked at that time because that is when the problem is present. They should be expecting you and you should be prompt. May be a spark, fuel or timing issue. Needs to be diagnosed.
TEENABURGE
My car seems to have a hard time starting. I have the starter checked and it seem to be just fine...What else should I have checked?
  • 110,190 POSTS
Is the starter turning the engine at a normal speed? Is it always hard to start? Has the check engine light come on? Has fuel pump pressure been checked?
SIRRIUS27
Like its starving for gas. when it does start idle fluctuates and when accelerating it dies. Ive changed the fuel pump and filter.
I just changed pcv valve. car idles good, but when driving, after it shifts starts to lose power,when i let off pedal, gains power again. no codes now.
check fuel pressure first.
start there
SIRRIUS27
update:dropped gas tank,replaced fuel pump,repaired gas gauge,car runs grrreeeaaat. thanks
good job
HOWDYCRAWFORD
My car wont start and it has a new battery and alternator. When i go to start it it turns my electronics on but the starter makes a rapid clicking noise. I was wondering if theres any way to find out if its a short from the battery to the starter and how to fix it.
Could be the battery itself or loose connections also the starter relay-start here
Oct 25, 2020 at 11:29 AM (Merged)
HOWDYCRAWFORD
Okay. Thank you cause I just got a new battery Sunday and it started for about 3 days and now it won't start at all. My radio and lights and everything works but the starter just clicks until I stop trying to start it.
RUBY DOSS SMITH
Wouldn't start when I came out of store. Started with a jump but when turned off wouldn't start again. I put new battery and alternator on and checked plugs and fuses but still wont start. Lights and everything work just wont start.
Good afternoon,
Does the engine crank over when it will not start?
RUBY DOSS SMITH
Doesn't do anything when trying to start.
Okay, chances are you could either have a battery issue or a starter issue.
I attached a wiring diagram for you to check and see if there is power to the starter in the start position.
Also, the battery needs to be load tested as well to be sure it is able to supply power.
CHRIS BUTYRIN
in the last few weeks the car has been slow to start in the morning, but better later on. Then today it was even worse even after driving it. I had the battery, starter and alternator tested and everything was fine. what could be the problem?
  • 110,190 POSTS
When you say slow to start, do you mean it is taking longer than normal or do you mean the engine is cranking slowly?
CHRIS BUTYRIN
Sometime when I turn the key it's like the battery is almost dead then it starts up after a few seconds - other times it starts right up!
  • 110,190 POSTS
If the starter sometimes cranks slowly, check to make sure all battery terminals are clean and tight. If they are, you need to have the starter checked to see if it is drawing too many amps when that happens. It may be in the process of going bad.
CHRIS BUTYRIN
Thanks - I'll look into that!
  • 110,190 POSTS
Let me know what you find.
PLABBE
  • 12 POSTS
I have a 96 taurus its very hard to start I have to start it 25 to 30 times before it will keep on running the it runs very bad for 2 t0 4 minutes the rpm starts around 100 and goes up very slowly until it 600 rpm then it kick in and iddles very good at 1000 rpm .It will iddle no problems until I try to push the accelerator I can bring the rpm to 2000 very slowly but no more or it will staled if I dont let go of the peddle .When iddling the fuel presure stays around 40 if I rev it up the fuel presure drops to 10 lbs.I think that it must be the fuel pump but I cant get why it would be hard to start like that .It makes no difference if I just put the key to run to pump fuel up the rails Itried to turn the key on until the pump stops many times before trying to start the engine and it makes no difference for the first start its always a long time and many minutes before it iddles good.I was wondering if its the fuel pump that is gone can I instale a electric one on the fuel line instead of replacing the very expencive one in the thank.
Thanks in advance to any reply or suggestionsto my problem.The engine is a 3 litre 24 valve.
2CARPRO JACK
  • 11,533 POSTS
Sounds like the pump is bad.Takes alot of pressure to get a good spray through the injectors, that is why it is hard to start. No , the tank unit is the only viable replacement
PLABBE
  • 12 POSTS
Thanks guys im replacing the pump in the morning I had to order it today if I have any luck it will be the right one .Here in northern ontario we have to order almost everything and its a pain because we have to weight 1or2 days to get the parts that why its nice to be sure of what we need if we dont want or vehicle out of order for days at the time.
I hope the pump will cure my trouble
Thanks again I apreciate the help.
PLABBE
  • 12 POSTS
I change the fuel filter that was the first thing I did and im changing it again as I change the pump.
Thanks for the advise .
PLABBE
  • 12 POSTS
I change the fuel pump today it starts right away but I sill can toutch the gas peddle it wont pickup I dont know what else to try now.A fuel pump,filter,I have good fuel pressure but cant accelerate any other idea guys?
Thanks again I really appreciate all the help.
