1998 Ford Taurus Repair Question
Asked on September 22, 2007
Can I put 04 taurus motor in 1998 taurus? Will it work?
I have a 98 Ford taurus 3.0 sohc motor and trans are both trash. I also have a 04 that has been wreck bad in the rear. My question is can I take the 04 motor, trans, wire harness and ecm and put it into the 98? I have already measured all the mounting points for the sub frame from the 98 to the 04 they are all the same. My plan is to install the 04 complete sub frame, motor, tran, wiring harness. After comparing the two on the 04 the abs system mounts to the sub frame under the hood on the 98 I can't see it at all. If I change all the parts out will this setup work?
