2CarPros - Car Questions & Answers
2006 Ford Taurus Repair Question
Topics covered: Sensor, Warranty, Dealer.
Asked on December 31, 2008
2006 Ford Taurus Trouble codes
Computer problem
2006 Ford Taurus 6 cyl Front Wheel Drive Automatic 76,500 miles
For 2 months my car has set a few trouble codes that all seem to be related. 0304(random misfires)
twice. Advised to change spark plugs, I did. Code P2270 (O2 sensor stuck lean, bank 1 sensor 2) has been set 2-3 times. Was advised that it usually indicates the sensor is bad. Code 0300(very simiilar to 0304, random misfires). The check engine lit has always went off after a day or 2. If I changed the sensor might that solve the other problems??
Avatar Asked by dwilliams1
Answer
Replied on December 31, 2008
p0300
3.0L 2V - MIL ON AND DTC P0300/P030X WITH P0316 IN MEMORY -2006 Ford Ta...
Page 1 of 1
TECHNICAL SERVICE BULLETIN
Reference Number(s): 06-10-2, Date of Issue: May 29, 2006 FORD:2005-2006 Taurus MERCURY:2005 Sable
Superceded Bulletin(s): 05-23-12, Date of Issue: November 28, 2005 Related Ref Number(s): 05-23-12, 06-10-2
ARTICLE BEGINNING
ISSUE
NOTE: This article supersedes TSB 05-23-12 to add a production fix date.
Some 2005-2006 Taurus and 2005 Sable vehicles built before 12/15/2005 and equipped with a 3.0L 2-valve engine may exhibit the malfunction indicator lamp (MIL) on with diagnostic trouble code (DTC) P0300/P030x and P0316 in memory, with no driveability concerns.
ACTION
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B39.14 and higher or B40.2 and higher. This new calibration is not included in the B40 CD. The calibration files may also be obtained at http://www.motorcraft.com.
WARRANTY INFORMATION
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
Operation 061002A 2005-2006 Taurus, 2005 Sable: Check Diagnostic Trouble Codes And Reprogram Powertrain Control Module (Do Not Use With 12650D, 12650D84) Description
DTC P2270:
O2 SENSOR SIGNAL STUCK LEAN - BANK 1, SENSOR 2
P2270 - O2 SENSOR SIGNAL STUCK LEAN - BANK 1, SENSOR 2 Description: The downstream heated oxygen sensor (HO2S) is forced rich and lean and monitored by the powertrain control module (PCM). The test fails if the PCM does not detect the output of the HO2S in a calibrated amount of time.
Possible Causes:
? Pinched, shorted, and corroded wiring and pins
? Crossed HO2S wires
? Exhaust leaks
? Contaminated or damaged HO2S
Tiny Answered by BMRFIXIT (expert)
19,736 answers provided
Replied on January 1, 2009
Regarding the 0300 code, I don't have 0316 in memory, so I don't know if the tech bullitin applies. My car's manufactor date is 11/05, so I'm not sure, and a Ford dealership would have to do it..Right ??
Regarding 2270..I guess I can unplug the wiring harness and lube the terminal connections and check the wiriing for any visable damage before I would buy a new sensor. Is this correct ??
Tiny Response from dwilliams1
2 questions asked
Replied on January 2, 2009
Call the dealer with your VIN #
and if so
Yes it has to go to the ford dealer
p2270
need to check for leaks
and check the wiring harness
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_144.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_76.jpg
