2004 Ford Taurus Misfire problems
2004 FORD TAURUS
119,000 MILES • 6 CYL • FWD • AUTOMATIC
PENNMATTHEWS
I started having misfire issues a week ago. The engine code came back with a problem in the primary coil. I changed the coil pak and still have the problem. I changed plugs, wires and the camshaft sensor all in an attempt to fix the problem. I am now getting multiple engine codes (random misfire, misfire in first 1000 revolutions, misfire in cylinder 6 and 2).
Yesterday while it was idling as I put in a bottle of injector cleaner I started pulling off wires at the coil to see spark activity and affect it had on the engine while it is running. the number two coil lead did nut put out any spark yet the others visibly did. Any ideas?
2004 Ford Taurus 3.0 not DOHC and not FlexFuel
Oct 22, 2009 at 7:15 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
I would suspect defective coil
remove and replace coil and let me know
Oct 22, 2009 at 7:22 PM
PENNMATTHEWS
Sure enough. It was a defective coil from the parts store. Figures the first thing I would change is defective and it led me to replace other parts trying to fix the issue.
Oct 27, 2009 at 5:23 PM
JONK777
I have a 2005 ford Taurus with the 3.0 motor. Car has 167,000 miles on it. The car idles right. But when you get up to speed ,it acts like it wants to blog down.
Apr 12, 2016 at 5:59 PM
