Mechanics
COLD WEATHER START UP PROBLEMS
2004 Ford Taurus
Engine Performance problem
2004 Ford Taurus 6 cyl Front Wheel Drive Automatic 90000 miles
2004 ford taurus se vin 2 below 25 degrees starts idle slowly flairs to 1900 rpms then slowly goes down to 0 and dies, slight rough idle as this happens, runs and starts fine after warm (above 25 degrees) did full tune up, ford parts also smoked intake for vacuum leaks, leaks in egr. Replaced with new from ford. Also took to ford had computer reprogrammed. No codes any help would be great Tim aka vipertek
Vipertek
January 8, 2009.
It was coil only failing on very cold days on #3 #4 cyl.
Vipertek
Jan 12, 2009.
