2CarPros - Car Questions & Answers
2003 Ford Taurus Repair Question
Topics covered: Brakes, Grease, Noise.
Asked on June 3, 2009
Front brake squeal while backing up
Brakes problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic 90,000 miles
I have a 2003 Taurus and I had the front pads done 20k
miles ago. When you back up the front drivers side brake
has a slight squeal. The rotor looks fine without any type or damage. The brakes work ok and it only seems
to happen when I am backing up? Any thoughts?
Thanks
Avatar Asked by jfmcgrathjr
Answer
Replied on June 3, 2009
BRAKE SQUEAL
Can be caused by vibrations between the disc pads and caliper, which can be cured by resurfacing the rotors, applying a nondirectional finish to the rotors after resurfacing, installing new pads and pad shims, or applying brake grease or noise compound to the backs of the pads.
Tiny Answered by rasmataz
68 questions asked
