Orifice tube location
DINOMOM66
  • 2004 FORD TAURUS
Where is the orifice tube located and what is the best way to get to it and change it. Thanks
Do you
have the same problem?
Tuesday, September 30th, 2008 AT 9:09 PM
SQM
  • 6,383 POSTS
The orifice tube is located inside the A/C hose that goes from evaporator to condenser.
Changing the orifice tube will require you to evacuate your A/C system and recharge afterwards.
Here is a helpful article of how to recharge the system:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
See attached for the replacement instructions.
Thursday, July 15th, 2021 AT 12:42 PM
JSANTIAGO1
  • 2002 FORD TAURUS
Evacuated system, replaced dryer, but cannot find orifice tube. Had low port reading of 38 psi, high port went above 500 psi. Will flush system after removing orifice, Mitchell does not provide the location either. Thank you.
Wednesday, July 28th, 2021 AT 12:13 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The orifice tube is hidden under isolation of the high side line here is the location and the special tools you need to take out the tube if it breaks.
Cheers
READY2GOWWFONMECHANIC
  • 12 POSTS
  • 2000 FORD TAURUS
  • 6 CYL
  • 4WD
  • 132,000 MILES
Can someone tell me where the orifice tube for the ac on the 2000 ford taurus is located.
BMRFIXIT
  • 19,053 POSTS
Check this.
https://www.2carpros.com/forum/automotive_pictures/99387_orifice_1_1.jpg
or this
https://www.2carpros.com/forum/automotive_pictures/99387_orifice_1.jpg
LEGOMOM
  • 1999 FORD TAURUS
My ac has stopped cooling and I now know I have to replace the orifice tube. I need a diagram of location of orifice tube location on a 99 ford taurus dual over head cam v-6. So if you could help me find a diagram it would be great. Thank you
WRENCHTECH
  • 20,758 POSTS
A simple orifice tube is not going to solve any problems for you. If the tube is restricted, that means the compressor is coming apart and all the debris has likely clogged the condenser also. If you do not fix this right you can destroy the entire system.
LEGOMOM
I have some one looking at my car but we cannot find the location of orifice tube. The compressor has been checked out and works fine. I only have to find where the orifice tube goes so we do not have pull more off the car searching for the location of orifice tube. If I could get a diagram of AC to orifice tube would help a lot. I am in GA and it is very hot in the summer and I cannot go without AC.
WRENCHTECH
  • 20,758 POSTS
I will remind you again that an orifice tube will not have a problem unless the system is contaminated and if you do not resolve the source of the contamination, your subsequent repair cost will be astronomical.
This particular vehicle does not have a replaceable tube. The tube is built into the liquid line that runs from the condenser to the evaporator and the entire line has to be replaced. The only way to see the tube is to cut the line open. Just the fact that your mechanic does not know this tells me that he is not experienced in AC whatsoever. I am a tech in South Florida and I have specialized in A/C repairs for many years and do these every day.
LEGOMOM
Thank you for your advise and help, hope you have a good day.
WRENCHTECH
  • 20,758 POSTS
You are welcome. Good luck with it.
LILDUKE
  • 21 POSTS
  • 1995 FORD TAURUS
In a 1995 Ford Taurus 3.8 engine police edition, does anyone know the location of the orifice? I have looked in the book and took off the tub that it said it was in, but I still cant find the orifice. So is it built in the tube itself or is it in the upper evaporator tube?
BMRFIXIT
  • 19,053 POSTS
FIXED ORIFICE TUBE
Fixed orifice tube, located in liquid line at condenser connection, creates a restriction in high side pressure line and meters flow of liquid refrigerant into evaporator core. Tube has filter screens on both ends. Tube is not adjustable. If determined to be faulty, fixed orifice tube is not adjustable or repairable and cannot be removed from liquid line. Fixed orifice tube can be replaced by replacing liquid line or by installing a fixed orifice tube repair assembly. Installation of the repair assembly requires sectioning the orifice portion from the liquid line to accommodate the repair assembly.
https://www.2carpros.com/forum/automotive_pictures/99387_KY334294_2.jpg
