Mechanics
HEATER BLOWS OUT COLD AIR
2002 Ford Taurus
Heater problem
2002 Ford Taurus 6 cyl All Wheel Drive Automatic 122, 00 miles
I BOUGHT THIS CAR 6MOS AGO AND THE HEAT NEVER WORK I HAD TO KEEP TAKING IT BACK
Ferris
October 12, 2010.
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Wrenchtech
Oct 12, 2010.
Is the engine running at normal operating temp? Are both heater core hoses hot when the heat is on and the engine is hot?
Let me know what has been done so far.
AD
AD
