2CarPros - Car Questions & Answers
2001 Ford Taurus Repair Question
Topics covered: Noise, Chirping, Serpentine belt.
Asked on January 2, 2006
3.0 efi
Taurus 3.0 six cylinder EFI approx. 120000 miles. I have a loud noise coming from the serpentine belt. It sounds like a bearing is bad. How do you release the tension on the belt so that I can try to determine what bearing is making the noise? The water pump seep hole appears to be good (not leaking). Any suggestions on what to check. The sound is similar to a high piercing bird chirping continously.
Avatar Asked by balanceguy63
Answer
Replied on January 3, 2006
It should be spring loaded. You should be able to use a 15mm wrench to pull the tensioner and relax the serpentine.
Tiny Answered by s0jrtorr
1 question asked
