EGR pressure sensor location
JRSHAMBO
  • 2002 FORD TAURUS
  • 6 CYL
  • 53,000 MILES
I have replaced egr valve, plugs and plug wires already. Engine still missing and sluggish with any throttle. Intend to replace fuel filter and EGR pressure sensor, but I need to know its location. I read about your coil pack advice already and it might be next, and where is it located also. Thanks. JA
Friday, February 6th, 2009 AT 11:02 PM
The EGR sensor is located near the EGR valve here are diagrams below to help show you the location. Check out the diagrams (Below). Disconnect the Differential Pressure Feedback Exhaust (DPFE) sensor. Please let us know if you need anything else to get the problem fixed.
Friday, February 6th, 2009 AT 11:50 PM
INSPECTORTED
  • 2002 FORD TAURUS
  • 6 CYL
  • 70,000 MILES
Need to know the location of the egr pressure sensor on a 2002 DOHC ford taurus
Monday, February 4th, 2019 AT 3:43 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_2_13.jpg
SCOOTER6321
  • 1999 FORD TAURUS
  • 168,547 MILES
My taurus is a v6 24 valve.
SATURNTECH9
  • 30,870 POSTS
Back by the the firewall towards the middle by the egr valve thats where they usually are. Theyhave hose going. To them and one hose comes from the exhaust. Usually the hoses fail and need to be replaced. Do you have any codes for the egr feed back sensor?If so what are the exact code numbers you have?
SCOOTER6321
The codes I have are P 0401 P 1131 P0171 P 0174
SATURNTECH9
  • 30,870 POSTS
I would start checking for vacuum leaks and the hoses to the egr pressure sensor. The P0401 is egr insufficient flow which could be a issue with the hoses to the feed back sensor. The P0171 and the P0174 is lean bank one and two could be caused by a vacuum leak. The P1135is o2 indicates lean again possible vacuum leak.
MARTYBERG
  • 2000 FORD TAURUS
I need to replace my DPFE sensor, however I cannot find it. This is a 2000, SEL, 3.04V. I was told it was on a mounting plate located (from rear view) on the right engine head, colosest to the firewall, its not there. Then I was told it was on the firewall behind the coil-pack just to the right, its not there. I know what it looks like, but cannot located it. Most all books seem to be written for 2000MY+ models, but all picts are fron the pre 2000 model year. Can you help? Maybe if you describe what had to be removed to get to it?
Thanks you (I did donate, and will again)
Martin Berglund
dian1marty@aol. Com
Canton, MI
ABADAY
  • 38 POSTS
It should be mounted to the back of the intake or in any of those other places but it will be silver not black
TAURUSWHEEL
  • 718 POSTS
Look under the air cleaner plumbing, above the transmission fill tube, why do you need to know, are you getting an egr code pointing to this item? It is a well-known failure part, it may even be covered under your federal emissions law, i'm not sure, I'm thinking 8 yrs or 80k miles for federal, covers most emission related parts.
TAURUSWHEEL
  • 718 POSTS
Also you can follow the metal tube from the egr mounting plate back behind the motor, there will probably be a couple of rubber hoses running off of two nipples, they will attach to the dpfe sensor
GRISELL0
  • 2001 FORD TAURUS
  • 6 CYL
Where is the sensor & solenoid in relation to the EGR valve? We replaced the valve yesterday & the engine light came on again this morning. We're hoping to repair it.
Monday, February 4th, 2019 AT 3:44 PM (Merged)
Differential Pressure Feedback EGR (DPFE) Sensor (3.0L 2V)Mounted on right front of intake manifold. See Fig. 1.
Differential Pressure Feedback EGR (DPFE) Sensor (3.0L 2V FFV)Mounted on right front of intake manifold.
Differential Pressure Feedback EGR (DPFE) Sensor (3.0L 4V)Mounted on right side of engine. See Fig.
Here you go:
MOM2MDK
  • 2001 FORD TAURUS
Engine Performance problem
2001 Ford Taurus 6 cyl Front Wheel Drive
Where do I find the EGR sensor on my car so that I can change it?
OBXAUTOMEDIC
  • 3,711 POSTS
It is located on the passenger side of engine about center of valve cove or in the area below the center Coil pack and it looks like this....
https://www.2carpros.com/forum/automotive_pictures/188069_01Taurusegrsensor_1.jpg
