Check engine light on for 2 years?
1999 FORD TAURUS
CATSRATZ
Hi, and in advance - Thanks!!!
From the time I test-drove this car, October 2004, it's always run great. But the SES light's been on since the test drive.
The automotive shop that sold it said they couldn't determine why, but it was no problem. At that time I didn't know it would not pass New York State Inspection for the next year with it on.
After quite a search, I found a shop that disabled the light long enough to pass inspection, and it passed easily. Unfortunately, I don't live in that area any more.
Just today I saw a local mechanic who says he is not able to pass it due to the SES light being on. My funds are very limited and the car drives great, too - lots of power, good start-up, etc.
This is now a headache of long-standing. I had the codes zapped off twice since purchase ("Oxygen sensor") but they always came back on within a few miles. I can't tell you enough what a GREAT running car this is otherwise!
My mileage is around 110,000 and I have a 6-cylinder Vulcan engine.
Thanks again.
Jenny
May 24, 2007 at 4:49 PM
RUDPRO
  • CAR REPAIR CONTRIBUTOR
  • 224 POSTS
You need to find a good mechanic who can hook up a scanner and analyze the live data while it's running. This guide can help you do it yourself
There should be more information than just oxygen sensor, like O2 sensor lean, O2 sensor rich. It could be the O2 sensor is bad, a vacuum leak, mass air flow sensor, leaky fuel injector that is making the code come up.
May 25, 2007 at 2:28 AM
CATSRATZ
Hi, and thanks for replying!
This mechanic is good, but in order to keep the post brief I left out a lot.
What's bugging me to death is that the car has run so great for so long now - making the expensive diagnosis and work(?) seem so unnecessary.
Though knowing almost zero about mechanics it seems to me that, since the car's run perfectly for 2 1/2 years, it'd be in rough shape by now if there really was a problem mechanically and not with just the light itself or something similar :(
May 25, 2007 at 8:40 AM
RUDPRO
  • 224 POSTS
It's funny because the light can come on for something minor and the car can run fine. Other times, the light won't come on when there is a problem. Go figure.
May 25, 2007 at 12:02 PM
DW95326
I am getting ready to sell my ford taurus and after spending hours cleaning it up, my check engine soon light came on. Do you have any possible reasons for this. I hadn't driven the car for a couple of months but it seems to drive fine.
Oct 24, 2020 at 12:08 PM (Merged)
BLACKOP555
  • 10,386 POSTS
make sure you hooked everything up right and didnt leave ne thing unplugged!
you can try removing the - battery cable foor an hour or so and see if that turns it off. if so drive it again, if light comes on then theres a problem.
you can take it to autozone for a freescan even some auto values or advanced autos will scan for you.
so with that said, have at it!
JENNIFER1273
1999 Ford Taurus
My 1999 Ford Taurus started overheating on me. It never reached fully hot on the temp gauge, but was warmer than normal. I drove it a couple miles home. It stalled on me once and didn't want to start back. It did, however, start back...reluctantly. I drove it 1/2 a mile home. My husband checked the car and found it to have a cracked radiator. Now, the check engine light is flashing and it's idling rough. The car has not been driven since this occurred. I know the radiator needs replacing, but any ideas on the flashing service engine soon??? Thanks alot.
  • 110,190 POSTS
Have the radiator repaired so it is safe to drive. Then take the car to a nationally recognized parts store and have them scan the computer for codes. If the light is on, there will be a trouble code stored in the computer and they will tell you what it is. Note: Most of these stores will do it for free, so there is no money out of pocket.
Let me know what you find.
VJGULLI
I have a question regarding may check engine light, I have had my check engine light on for a few months and just recently used a code reader to attempt to find out just what the problem was. I got a 02-heat sensor bank 1 sensor 2 code as well as an auxiliary manufacturer emissions code. I changed all 3 02 sensors and changed the fuel filter, air filter, cleaned fuel injectors (sea foam) and changed the oil . The light came back on after reset and codes remained the same. Very frustrating, can you offer any suggestions?
Oct 24, 2020 at 12:09 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
What do you have for code s
for us to further help you we need what you have for codes and engine size
not all o2 sensors related codes means sensors are bad
KATIEK68
This afternoon my Service Engine Soon light came on as I was driving home. I just had the oil changed last week, and they checked my battery and fluids and said everything was fine. Lately (within the last 2 weeks), I've noticed, though, that when I'm idleing at a light or something, my RPM's get really low for a second, almost like it's going to die out and then it kicks back in. I thought it might be the spark plugs, but that was just a guess. I've heard that the light coming on could just be some sort of "routine maintenance" warning, as I was planning on having the transmission fluid changed next week. Could someone tell me what this could mean? I don't want to get stuck on the side of the road somewhere, as I commute 50 miles to school every day. I won't be able to take it in until next week, due to financial issues. Any help is greatly appreciated. Thanks.
BMRFIXIT
  • 19,053 POSTS
The light coming due to a problem
the computer detected an issue where the car emission not to spec.
best way to deal with this ,is to get the car scanned for codes
codes will help ID the troubled area
and what is the cause
most part stores and repair shop car help u
check around some have this service for free
also u can check gas cap make sure its on and tight
open hood and check for vacuum leaks
good luck
FORDSEL
  • 8 POSTS
Before u spend any money on new parts check all your vacume hoses fords are notorious for hose leaks. if you have to get a hose or big straw and put it up to yer ear and move it around all the hoses thats a pretty easy way to find leaks. There is also a curved or elbow shaped hose under the intake check that one its very common to melt and break.
OLBOO
we ran out of gas and now it doesnt idel the same ( very low) and will die from time to time, and the service engine soon light is on now.
Oct 24, 2020 at 12:10 PM (Merged)
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
IDGROSS
Changed PCV and hose and have driven 168 miles and the service engine light still is on.
Good afternoon.
What is the code so I can help you narrow the area of failure?
IDGROSS
I do not have the code number, but the tech said it shows a vacuum leak PCV or ?
PCV and hose was replaced.
Need the code as there are way too many possibilities. See if you can go to a parts store and have them read it for you.
Ask them to read the long term trims for.
This is free service.
VERBOB
I was driving along approaching an intersection. BAMM..engine shuts off. So I throw it in neutral and turn the key - then EVERY shuts off. Not even hazard lights!
Had someone come to give me a boost, popped the hood and connected the jumper cables - nothing. looks like bad connection on the battery. Cleaned off the corrosion, tightened the connections. Finally boost works.
NOW there is a ticking (lifters?) and Oil light is on (and check engine light too). These were NOT on before it shut off. Checked the Oil - ITS FULL.
Its been suggested that perhaps the Oil pump driveshaft is worn (as well as the bad connection on the battery).
Any ideas?
Oct 24, 2020 at 12:11 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
If it were mine,
No more crankin' till I had a Mechanical Oil Gauge screwed into the spot where the "electric" sending unit is now....Must have some presure to run it
Like was suggested, maybe the oil pump is not working for some reason....Must have pressure while running!.....Things do break sometimes.
Investigate check engine light by "coding" it---Find someone who will stop by and check it (I've always kept a good relationship with the fellers at Autozone and Advance Auto, They have in the past came to my house, after work and coded something that I was scared to drive)...If you can get it there, CODING IS FREE!!!
I hope this helps you
I hope its not real serious
The Medic
VERBOB
Sadly, there is no Autozone here, although I will ask around to see if I can get someone to scan it for me.
Just spoke with a mechanic, he suggested that I change the Oil filter as sometimes they get clogged and oil bypasses.
If not, its a couple hundred dollar pump and most shops want to pull the engine to swap it :(
Thanks
STEVEN26
Transmission problem
1999 Ford Taurus 6 cyl Wheel Drive Type unknown Automatic 130129 miles
i just bought a 1999 ford taraus tonight and i was driving it home at 60 to 68 mph and the service engine soon light came on and it was running at 3,000 to 3,500 rpm's .. any answers on what it might be? car was not drove in a few months got soulation? mabe a full blown tune up?
FLEXY5
  • 512 POSTS
Have it scanned and post the codes back here. We'll see if we can get you an answer. Some parts stores will scann for free.
TEIRA
  • 5 POSTS
1999 Ford Taurus Front Wheel Drive Automatic 72,000 miles
what does codes PO 171 & PO 174 mean by System Adaptive fuel too lean (Bank 1&2) what is a Bank
BMRFIXIT
  • 19,053 POSTS
Most common is a vacuum leak
check PCV valve and tube
bank is teh side of the engine where cylinder 1 AND 4
many TSB on the subject
i will try and find some if need me to
check PCV valve line 1st
TEIRA
  • 5 POSTS
If there is any more information or help you can tell me I would be very greatful.
BMRFIXIT
  • 19,053 POSTS
All TSB state to check for vacuum leaks using smoke machine
if no vacuum leaks found
and or have a driving concerns as lack of power or poor performance
check clean MAF sensor or replace
TEIRA
  • 5 POSTS
I had asked you about a problem i had with my car and we checked for vacuum leaks and also checked the PCV valve and tube for leaks and the service engine light did go off but after driving it a little the light came back on. now the idle is off. In park it idles to high and when in drive it idles to low and then it dies. In park it idles at 2 marks above the 1 mark and in drive its at 1 mark below the 1 mark. When you are driving it, it goes as high as 2 1/2 to 3 rpms when it changes gears. I hope you can help.
thank you
ANNA MOSES
My car has over 127,000 miles and the service engine light just came on.
Oct 24, 2020 at 12:12 PM (Merged)
Good afternoon.
The check engine light is an indication of a fault in the fuel control system. There is a code stored that needs to be read and then a flow chart is followed to find the failure and repairs made.
A parts store can read it for free. Once we know the code we can further help you.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
