1999 Ford Taurus
1999 FORD TAURUS
GREGL_53
Noises problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic
I have a 99 taurus 6cyll ohv aut trans with 150000 miles on it. I had a engine installed about 2 years ago from a wreck with 40000 miles on it . The engine seems good and strong burns no oil runs smooth and fine. My problem is if I take off somewhat quickly I am getting a strong poping sound from the front. I cant quite figure exactly where. Also if I punch it from 1st to second same sound. It doesnt do it after that or if I pull out slowly. It doesnt do it in reverse. I checked the cv joints and axels by visual and by shaking and there was some movement backward and forward on both and a little on the left from side to side but not bad. The boots look good. I checked the mounts as best I could and foun one bolt missing on the right mount and after a test drive found a bolt on the ground on the left side. My repair manual is for 1989 to 2001s T he mounts they show are not from a 99 The transmission seems ok with shift points where they should be only if I punch it alittle the pop from 1st to second I can hold the brake give it gas and have the pop. It is good one plenty of sound. Does anyone have any idea of what this coul be?
Apr 15, 2008 at 5:35 AM
