Mechanics
HEAD GASKET TEST
1998 Ford Taurus
Engine Mechanical problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
what kind of test can you run if any to see if your head gasket is blown I took the thermostat out and it builds up pressure because my coolant and water is gone it might be looseing water while driving thanks
Larry 35773
December 30, 2008.
You will need to have the cylinders compression tested. Do you have a frothy oily substance in your overflow tank? Is the exhaust smoking white.?
Dave H
Dec 30, 2008.
