1998 Ford Taurus ABS
1998 FORD TAURUS
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
TINMAN41
Hello, I just changed front and rear brake pads and the ABS light still comes on in my dash board, The car stops fine, the brake peddle doesn't go to the floor. what other problem would there be?
Jun 3, 2010 at 2:03 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
[quote:0513a3c008="tinman41"]Brakes problem
1998 Ford Taurus 6 cyl Two Wheel Drive Automatic 150000 miles
Hello, I just changed front and rear brake pads and the ABS light still comes on in my dash board, The car stops fine, the brake peddle doesn't go to the floor. what other problem would there be?[/quote:0513a3c008]
If your abs light is coming on then you have a problem with your abs you need to get your abs codes read.When you get the abs code numbers let me know and i will help you out with that.
Jun 3, 2010 at 2:24 PM
TINMAN41
where do I find this ABS Code?
Jun 3, 2010 at 2:32 PM
SATURNTECH9
  • 30,869 POSTS
You have to go to a shop or some where they can use a scan tool to read your abs codes from your abs computer.Try autozone see if they can rent you a tool or scan the codes for abs for you.Let me know what you find.
Jun 3, 2010 at 3:02 PM
