Loss of power, hesitation, rough idle?
1997 FORD TAURUS
196,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLIE304250
  • 9 POSTS
After my car has set for a while I can drive for about 16 miles and my car seems to lose all power, and I have no acceleration at all. I can shove the pedal clear too the floor and the car won't go nowhere, but it is still running. When I rev up the engine it will go to about 3,000 rpms then drop to about 2,000 or less while I still have my foot on the gas pedal. My engine misses also. I have replaced the camshaft sensor because it was bad, and after I replaced it I got a code for SYSTEM TOO LEAN, I have replaced the spark plugs, plug wires, fuel filter, and the fuel pump, and I still have all the same problems with the loss of power, but everything that I have replaced was necessary, because I was only getting 20 psi from my old fuel pump, now I am getting 48 psi. I have been troubleshooting this for over a month now and I still have not figured it out, I have checked for vacuum leaks for the past week and they all seem too be working ok. What else can I do?
May 11, 2010 at 2:50 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
check exhaust system and catalytic converter it sounds like it is clogged but to be sure these guides will help us fix it
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
May 11, 2010 at 6:02 AM
CCOUNTZ
149,000 Automatic. After starting will idle fine for a minute or two, then the engine will begin to lose power. At that time a beeping sound will go off (not like the saftey belt....more like a beep then a dinging). The power steering will also go out then shortly afterward will die totally. However, the battery can be jumped with very little effort.
Aug 22, 2020 at 10:32 AM (Merged)
JWALTH02
  • 180 POSTS
Take the car to an autozone or checker if you can and have them test the altenator. If you can't get it there then take the altenator out of the car, pretty easy to do, just take the belt off, undo the bolts and disconnect the wires, and have it tested.
HRSLDY62
Just wondering what the problem could be when driving the car on a warmish to hot day, if I take the revs over 2000 the car heats up, yet the temp gauge does not register more than half, yet upon stopping the car, and even just driving for ten minutes, the engine is very hot and smells dry. There is plenty of coolant in the bottle when checking it, if I continue to drive it, it will get to the stage where it has no power, it will chug along for a few seconds before stalling. If I let it sit for around 10 minutes, it starts again, like new and will travel further. It is a headache especiallly cannot drive it in peak hour traffic, stop start driving, on a warm day. No one as yet has been able to define the problem, no one wants to deal with the Taurus, getting to the point where I just want to sell the damn thing as its becoming unreliable in city driving. On freeway travelling, keep the car on around 90 klm at a steady pace, it drives lovely, very fuel efficient, cruises well. City driving, it will stall to stop the engine from overheating even though temp gauge is not on hot. Smells of a dry radiator. I figure there is a blockage somewhere, but as the mechanics all tell me, it could be a 100 dollar question or a 1000 dollar question?? Even Bayfords. Have had it on a machine, let it run for 6 hours straight, didnt stall once, only when going up and down gears stop and starting. Any clues? Just a little more info, when I first purchased the car it had so much power it was scary, now it doesnt have any, I put the foot down to kick back to second and hardly get a reaction, just a car thats struggling.
Aug 22, 2020 at 10:33 AM (Merged)
TECHMAN1
  • 82 POSTS
I have been here and I have done this. Bought the tee shirt and sold it at a yard sale.
You likely have a crack in a head gasket that only opens badly in heated stop and go traffic, but when cruising on the highway, the combination of cooling air rushing through the radiator and around the engine does not "swell" the crack open as far.
This crack in the head gasket is putting high exhaust pressure into the water jacket causing coolant to not move. That is why it gets hot but does not show on the temperature gauge. The Hot water cannot get to the gauge sensor because water is not moving.
The flip side of the coin is when you shut it off and let it cool, the high radiator pressure forces antifreeze into a cylinder and you get white smoke for a minute on cold start up.
You probably would not need to replace both head gaskets. You could probably pull the spark plugs and see evidence of antifreeze on one of them.
There are several cheap, simple tests for exhaust pressure in the radiator. The simplest is a radiator cap gauge. If it ever exceeds 17psi, then there you have it. You could get this checked for free or very cheaply if you call around.
By the way, just to entertain you, I live in a University town. A very rich out of town girl came to University for a 4 year law degree. She was given a new 93 Taurus to take to college. In her 3rd year, the car blew a head gasket. She took it to the local repair shop and they replaced the water pump and the thermostat. Not fixing the problem, she buys another car and just parks the Taurus. She waits until graduation week to place an add in the paper to get rid of this car. (I'm going away in 4 days and never coming back.) I start the car and it makes a vapor cloud 40 feet tall (until it burns it off). She says, "Reimburse me for the water pump and thermostat repair bill and you can have the car($165).
This is a clean, never been smoked in, deluxe Taurus with power everything, nice stereo, and great air conditioning.
I take it to the local car engine machine shop. For $1,000 they pull the heads, mill them, all new valves and valve springs, and head gaskets.
I give my wife a deluxe Taurus for $1,165. She drives it for 5 years. I give it to my daughter. She drives it for another 5 years and still drives it today.
You may laugh please,
Ken
HRSLDY62
Hey Ken, thankyou for your advice, its like someone has just opened a window and let the breeze in.... I will take your suggestions now to my mechanic and see if it opens the doors for him too. Seems like here in Australia nobody knows anything about the taurus'. Or they dont want to! I really like my car and would like nothing better than to have it running the same as before. Thanks again, good advice taken. Kay
CATDADDY1953
I have a 96 ford taurus that has been having a problem for awhile. Its so bad now you can't drive it. Whats going on is it will take throttle if you just crack it about a 1/4 throttle,anymore it falls down,also it misses when it reaches about 3800rpm. If you give it half throttle it falls on its face. had a tune up done on it and they said fuel pressure was fine...also replaced the catalytic converters..My thinking is when the cats plugged possibly some trash got lodged in the muffler causing too much back pressure when you advance the throttle...Would a faulty MAF sensor give these symptoms??....also thought it may be the ECM as they are known for problems at this age.....Any thoughts on this will be appreciated.
Thanks
Aug 22, 2020 at 10:34 AM (Merged)
BADWUFF
  • 13 POSTS
You can have fine fuel pressure at idle, but not enough flow at higher engine speeds. one simple test if possible is to disconnect the fuel line and route it into a 2 liter coke bottle, then turn the key on and watch the flow. theres a sock in the tank that can plug over time. first guess would be electronic tho.
CATDADDY1953
The fuel sock makes since as when it stalls you pull over and kill it then restart it goes for awhile but its getting worse....since killing it releases the fuel...the sock will release the crud for awhile.....Have to pull the tank and check that out.
Thanks, George
PHATBOISLIM
it takes my car a while to crank we checked the fuel pressure by turnng the switch but dont crank up it says 15psi but when i crak it says 30-40 psi runs good some times but when i lay in to it it bogges down then kicks in and runs fine i have replaced the fuel pump, filter,strainer,fuel pressure regulater, still does it i have checked the egr valve it is good the engin codes say bank1 and bank 2 are lean what do u think it is
BMRFIXIT
  • 19,053 POSTS
Check for vacuum leaks and intake gasket
clean ,check MAF sensor
ANGLBEBE
I have a 1996 Ford Taurus GL 3.0 V6 engine It has a leaky radiator, and I used Baars to temporarily fix it. Only ended up gumming up the heater core. They Blew air threw and flushed the system. Now when it is running for say about 30 minutes or so it starts to lose power. Acts like it wants to stall the temperature gauge reads that it is in the half way mark so it doesnt look like its over heating. But there is a burning smell, almost like a burnt caliper barbequed antifreeze type smell.. and when you lift the hood after shut off you can hear sizzling and ?knocking? sounds...
BMRFIXIT
  • 19,053 POSTS
The sounds is an indication of overheating
I would have them run a headgasket test
and do a block /coolant system pressure check
if possible run it with out the thermostat check if its better or if it take longer for it to get to that point and if so suspect an engine problem
good luck
FLASHHEAT
  • 8 POSTS
is it possible to have the timing belt slip or lose "teeth" if you overheat the engine hot enough? i got it hot enough for the engine to shut itself down. i was losing water/anti-freeze thru the overflow reserve, and ran it pretty "dry". after i refilled it with water, i tried to start the engine and it seemed as if i lost half the compression. (i should explain that the feeling of loss of compression only occured during my attempts at starting the car. although i noticed a little loss of power while driving on the freeway back to my house 20 miles away.) it took 5 or more minutes of repetitive trying before it started and lots of pumping the gas --- until finally! though it would not stay running at idle. also it would sputter, or more accurately described "backfire", as if it had a carburator. the same thing is happening now when i attempt to start the vehicle, failing miserably. it sounds like it's backfiring back down a carburator (the cylinder is trying to fire while the piston is still on its upstroke.) if my assumption is correct, is the timing gear/belt located directly behing the water pump as in older vehicles? is it very involved (i.e. how long should it take to do the job? thanks
TAURUSWHEEL
  • 718 POSTS
If you've overheated the engine as bad as it says in your post, you'll be lucky if you haven't ruined the engine.. don't ever continue to drive when the engine is or shows indications of overheat, it is probably the worst thing that you can do.. first thing i would do is a compression test, that'll tell you sort of the condition internally, post back what you find
KVICKERS
My car has been Acting up When driving it runs hot alot and has some misfire...I was driving and It shot up on the tempature gage and Now will not drive over 30 miles an hr and Will start idleing high and wont go over 30 miles an hr !!
  • 110,190 POSTS
If you overheated it too much, you may have blown a head gasket, intake gasket, warped a head... Are you seeing any white smoke from the exhaust? Any coolant getting into the engine oil? Are you consuming coolant? Is the check engine light on?
DURAND88
my car is bogging out when i accelrate on the highway then boggs out when i try to go after i stop, what could be the problem
Aug 22, 2020 at 10:35 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Here are so possible causes....
Weak Fuel Pump and or Fuel Pressure Regulator
Clogged Fuel Filter - when was it last changed
Worn Plugs and/or Wires - When was last tune up
Clogged Catalytic Converter
THERESAF77
Shakes or Wobbles problem
1996 Ford Taurus 6 cyl Two Wheel Drive 100100 miles
lots miles been well taken care of oil changed regulary ect...
I drive it for about an hour or so it starts to shake and does not want to run??? I pull over or manage to get home and have husband drive it it does not do it..think when it gets engine gets hot it seems do this ??? I work about 29 miles from home and some times it does the shaking and sometimes it doesn't do it for a few weeks????
i
BMRFIXIT
  • 19,053 POSTS
Check for codes I would suspect fuel pump
Should check it for tune up and also check fuel pressure and flow
RICK44129
Before the engines Temp reaches normal, the Car drives Wonderful (3.8l v6) accelerates as it is supposed to, but once it warms up, no matter how hard I accelerate it accels as if im only pressing the gas a a tiny bit, i have replaced the Throttle position sensor, (it was driving fine after replaceing it even after warmup, until the next day, it was back to problematic) fuel pump, plugs, wires, distributer cap and rotor, neutral safety switch. This issue is also causeing my MPG to suffer drastically, getting about 9 mpg, But only when the car is warm. I took it to a couple repair shops , but after telling them the issue, they turned down the buisness, seems no one even wants to LOOK at it...
Aug 22, 2020 at 10:37 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
Has anyone performed a back pressure test on the exhaust when it was hot?
RICK44129
No. But that sounds like a very good idea. I will try get it tested asap.
SATURNTECH9
  • 30,869 POSTS
I think so let me know what you find.
RICK44129
It has been a very long time, i finally got the money for the cats, and o2 sensors, my cats were mostly clogged, but, the acceleration problem is still there, even tho the car feels alot better, and the gas milage raised a bit, but it still is not good . A recent update is , I acceled full throttle so show someone how it accels so bad, and it jumped like as if i was letting go of the throttle or somethingthen violently smashign the throttle, (which sounds like TPS but i changed that already)
i DID need cats, so im glad i changed them, but this issue is eating me alive. im mainly worried about my new cats, wondering if this issue is the reason my cats got clogged up. telling the computer to dump too much fuel in cylinder
SATURNTECH9
  • 30,869 POSTS
Has anyone done a Injector balance test?Or tested the coolant temp sensor?
TRICITY
I was on my way home from work. I take highways for about half the commute. It ran fine then. When I started on the local roads, 1 was only able to make it go 20-25 mph, and that was while pushing the engine. I could move the Sshifter without a problem, just thre engine itself won't shift.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
RMK74
  • 11 POSTS
I have a 1995 ford taurus GL with 116,000 mi. I think I've posted about this before, but I've tried several repairs and nothing has helped (enough.) Here's the deal-when I press the gas I feel resistance in the peddle and it seems I have to keep pressing it. There is no loss of power; it's not an electrical problem (I don't think.) I've had a spark plugs replaced, fuel induction, new tires, left outer tie-rod replaced, an alignment, the air filter replaced , and the peddle lubricated. These things have helped alittle but the problem is still happening and seems to be getting worse. My gas mileage seems to be deteriating and I occasionally smell gas, especially shortly after I have filled the tank and then driven. Also, The temp guage occasionally reads slightly above normal when I go 40+ mph. Any help would be greatly appreciated![/i]
PEPPERMRJ
  • 1,158 POSTS
All that is left is to check the throttle cable itself.
The gas smell could be a detached hose from the evap canister. Any engine lights?
Check for fuel leaks along the line, by the filter, and tank.
Good luck and let us know. :)
HCCDESTINYBECK
my transmission will not shift into second gear. I checked the fluid and it was fine I also changed the filter. What could cause the transmission not to shift? It will still go, but not over 35 mph.
BMRFIXIT
  • 19,053 POSTS
suspect internal tranny failure
check for codes
Not only do we need to check for codes but I would suggest we check the fluid pressure. It sounds like there is either a leak internally not allowing the vehicle to shift or the fluid pump is failing.
Here is a flow chart that will help with this. Let us know what you find. Thanks
Aug 22, 2020 at 2:02 PM
DES232323
When i take off my car has little power it surges. It seems to get worse when ac is on. Ive replaced egr pressure sensor that melted replace mass air flow. When cold first running runs good after while when driven awhile has problems.Car idles fine no stalling just when taking off no power have to floor it to move. No codes for items only code for egr pressure sensor which melted. Thank you.
Oct 22, 2020 at 11:38 AM (Merged)
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation. much appreciated I would have a transmission shop look at the vehicle, sounds like you may have a bad torque convertor or possibly burned clutches inside the transmission !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1179.png
DES232323
Thanks for the info we had transmission replaced last year. It only started to act up after we had a fuel system cleaning just other day.Transmission shifts good.Any other possible repairs? Replaced one 02 sensor because broken. Bad cata conveter? Or egr valve? But no codes for those.
Thank you again
Mr.Sanders
DAVE H
  • 13,384 POSTS
Try removing and checking/cleaning the TPS
Throttle Position (TP) Sensor
TP sensor monitors throttle plate opening. Its signal to the PCM is proportional to throttle plate opening angle. The TP sensor signal affects air/fuel ratio, injector timing, idle speed, EGR flow and ignition timing. The TP sensor is mounted on throttle body, at throttle plate rod.
