3.0 litre 24-valve, auto.- Check engine lite on for last 70k miles- Cleaned out ther plenum with carb cleamer and fixed 2 vacuum leaks, so the car idles better
Friday, June 29th, 2007 AT 10:01 AM
HARLEYRYDER
MEMBER
1997 FORD TAURUS
6 CYL
FWD
AUTOMATIC
125,000 MILES
When I start thr car it takes too long to start. After starting it runs perfect.
Sunday, October 25th, 2020 AT 11:27 AM
(Merged)
MECHANIC
Hi:
What you need to do is check for fuel pump pressure drop off. When you turn the key on, there should be pressure. WHen you shut the key, it should hold pressure for some time. WHat you need is check for fuel pressure drop off when you first shut the key. IF it drops off right away, that is why it takes time to repressurize the system and longer to start.
Here is a how to for checking fuel pump pressure and drop off. Check it and let me know what you find.
Engine will not start unless accelerator pedal is pressed to the floor. When engine starts it has no power or acceleration and catalytic converter turns red and gets hot enough to catch on fife. Fuel pressure is at 35psi.
SPONSORED LINKS
Sunday, October 25th, 2020 AT 11:28 AM
(Merged)
BMRFIXIT
MECHANIC
Check firing order, make sure its firing on all cylinders
check for excessive fuel in cylinder and on plugs
check fuel pressure regulator
remove O2 sensor before catalytic converter and check exhaust back pressure
if high suspect clogged catalytic converter
(Merged)
RAY.TAYLOR
MEMBER
1 POST
1997 FORD TAURUS
6 CYL
2WD
AUTOMATIC
135,000 MILES
Starts and runs fine when engine is cold. After is warms up it cranks about three times longer then when cold. After it starts runs rough for about 15 seconds than smoothes out. Do not notice any problems when driving
(Merged)
SERVICE WRITER
MECHANIC
This is something that is going to require some troubleshooting to find the cause. When the problem happens is when it can be tested. I suggest making an appointment with a shop you are comfortable with to do the testing. Set up an appointment so that when you show up, the problem will be present and the diagnosis can be done. Make it clear that when you get there you want it checked at that time because that is when the problem is present. They should be expecting you and you should be prompt. May be a spark, fuel or timing issue. Needs to be diagnosed.
(Merged)
TEENABURGE
MEMBER
1 POST
1997 FORD TAURUS
6 CYL
FWD
AUTOMATIC
163,000 MILES
My car seems to have a hard time starting. I have the starter checked and it seem to be just fine. What else should I have checked?
(Merged)
MECHANIC
Is the starter turning the engine at a normal speed? Is it always hard to start? Has the check engine light come on? Has fuel pump pressure been checked?
(Merged)
SIRRIUS27
MEMBER
1996 FORD TAURUS
155,000 MILES
Like its starving for gas. When it does start idle fluctuates and when accelerating it dies. Ive changed the fuel pump and filter.
I just changed pcv valve. Car idles good, but when driving, after it shifts starts to lose power, when I let off pedal, gains power again. No codes now.
(Merged)
MECHANIC
Check fuel pressure first.
Start there
SPONSORED LINKS
(Merged)
SIRRIUS27
MEMBER
Update:dropped gas tank, replaced fuel pump, repaired gas gauge, car runs grrreeeaaat. Thanks
(Merged)
MECHANIC
Good job
(Merged)
HOWDYCRAWFORD
MEMBER
1996 FORD TAURUS
3.0L
V6
FWD
AUTOMATIC
150,000 MILES
My car wont start and it has a new battery and alternator. When I go to start it it turns my electronics on but the starter makes a rapid clicking noise. I was wondering if theres any way to find out if its a short from the battery to the starter and how to fix it.
(Merged)
MECHANIC
Could be the battery itself or loose connections also the starter relay-start here
Sunday, October 25th, 2020 AT 11:29 AM
(Merged)
HOWDYCRAWFORD
MEMBER
Okay. Thank you cause I just got a new battery Sunday and it started for about 3 days and now it won't start at all. My radio and lights and everything works but the starter just clicks until I stop trying to start it.
(Merged)
RUBY DOSS SMITH
MEMBER
1995 FORD TAURUS
6 CYL
2WD
AUTOMATIC
135,860 MILES
Wouldn't start when I came out of store. Started with a jump but when turned off wouldn't start again. I put new battery and alternator on and checked plugs and fuses but still wont start. Lights and everything work just wont start.
(Merged)
MECHANIC
Good afternoon,
Does the engine crank over when it will not start?
