Mechanics
DOES NOT BLOW WARM OR HOT AIR
1997 Ford Taurus
Heater problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic 151250 miles
The AC works great. Changed thermostat still no warm air will come out of the vents.
Had a mechanic think the " flap" might be stuck but can not locate the " flap" to control warm/cool air.
Can you help?
Jack24
October 28, 2008.
Check heater hoses if they both hot
if not you need to flush the heater core
if both hot suspect blend door actuator
its on the HVAC box check it and or have it replace
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
BMRFIXIT
Oct 28, 2008.
AD
