2CarPros - Car Questions & Answers
1997 Ford Taurus Repair Question
Topics covered: Sensor, Engine, Wheel.
Asked on October 19, 2009
1997 Ford Taurus Could this have happened?
Brake Pads-Front, Metallic Tru-Stop (TS7479M)...$44.89
Wheel Cylinder-Rear (37857)...$22.19
89054851 SENSOR/EGR Valve Position Sensor (214-1356)...$129.88
F58Z 12A112AA/Camshaft Position Sensor (DU5T)...$109.88
CAMSHAFT POSITION SENSOR SYCHRONIZER (F58Z 12A362BA)...$159.85
Shop Supplies...$5.83
Replace front disc pads and resurface rotors, Replace front brake pad linings, and resurface front brake disc rotors. - $139.50
WHEEL CYLINDER - Remove and Replace - Rear, One Side
[Includes: Repack wheel bearings where applicable, bleed system and replace shoes if necessary.] - $93.00
E.G.R. PRESSURE FEEDBACK SENSOR - Remove and Replace - $46.50
CAMSHAFT POSITION SENSOR - Remove and Replace - LX, O.H.C.-DOHC
[Includes: Component test.]...$65.10
DIAGNOSE FOR EMISSIONS, SCAN FOR COMPUTER CODES, CODE PO340 AND PO401, CAM SENSOR AND DPFE SENSOR NOT FUNCTIONING...$46.50
Avatar Asked by Matafy
Answer
Replied on October 21, 2009
Check tranny fluid
cam may be out of SYNC and need to be rechecked and adjusted
should have them recheck that
Tiny Answered by BMRFIXIT (expert)
19,736 answers provided
