Mechanics
CHANGING MY WATER PUMP
1997 Ford Taurus
Engine Cooling problem
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic 144000 miles
Im having problems changing my water pump on my car I ask my father the mechanic for help but he lives in a diferrent sate I jack it up some of the bolts off it my serpentine belt is already of I cant locate where the moter mount are so I can jack my egine up to the rest of my water pump I need to see in a picture please help me email is cjmace2003@gamil. Com or cell number is 623-330-0336
AD
Chris macewicz
June 4, 2010.
What do u have for engine?
WATER PUMP
Removal
Disconnect negative battery cable. Drain cooling system. Release drive belt tensioner. Remove drive belt. Remove radiator hose and heater hose from water pump. Remove A/C compressor-to-water pump brace (if equipped). Remove water pump bolts and remove water pump.
Installation
Clean gasket mating surfaces. Tighten water pump bolts to specification.
To complete installation, reverse removal procedure. Tighten bolts to specification. Fill cooling system. Start engine and check for leaks.
BMRFIXIT
Jun 4, 2010.
My question was still not answered
AD
Chris macewicz
Jun 4, 2010.
AD
