Mechanics
#5 WET WITH GAS
1997 Ford Taurus
Engine Performance problem
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic 109000 miles
ive changed plug, wire, coil pack and no change it has spark and looks strong it starting to smoke out the back but I believe its from the raw gas no aantifreeze that I see and oils still clean once I get it to move whch takes a lil finess it kinda evens out and around 55 up it seems almost ok
Imhere667
June 2, 2010.
Check if the injector/s or the fuel pressure regulator are leaking
Rasmataz
Jun 3, 2010.
