Ford Taurus 2002 Ford Taurus Where Is The Shift Solenoid
2002 FORD TAURUS
AMASON63
I am having problems with a shift solenoid and need to find its location?
Nov 5, 2010 at 2:19 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
They are located on the valve body so the transmission pan will need to be removed. Here is a guide and a diagram to help you find the correct solenoid with diagrams below to show the location. This guide will walk you through the pan and fluid removal:
Apr 13, 2021 at 7:55 PM
SIMPLYCOUNTRY_33
I'm not sure how post on here. But having issue with transmission in my 1992 ford Taurus gl 3.0 6 cylinder. The transmission stops pulling but you can turn it off and restart and it will drive little more, then quit again. Amd just keeps repeat that pattern of giving out and restarting for it to work. Have few ideas what maybe wrong. But maybe someone knows for sure?
  • 54,350 POSTS
It sounds like it is low on fluid or the unit needs to be serviced because you have a filter that is plugged up. Here is a guide to help us service the unit so we can go from there:
Cheers, Ken
SIMPLYCOUNTRY_33
I have done did and always keep eye on fluids in my vehicles. This just happens be one i just purchased.
  • 54,350 POSTS
Okay, it could be a transmission shaft speed sensor can you run the codes to see what comes up?
Cheers, Ken
SIMPLYCOUNTRY_33
Can't have it put on computer due to check engine light not on. Just been doing research of what problem could be.
BWEAVER
Where is the torque converter clutch solenoid located? it has a 3.0 v6 in it
Apr 13, 2021 at 8:04 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
RKOHL1956
can this be fixed at home? i am proficient with most repairs. i have heard that this is most likely a faulty engine speed sensor on the transmission, with a corresponding "service engine soon" light on.
JGAROFALO
  • 489 POSTS
If you are proficient with doing your own repairs, this is one that you may be agle to handle at home, but it is not a speed sensor. You have a problem with a shift solenoid.
A quick tutorial.....
The transmission is controlled by the computer. It reads inputs from the engine together with speed inputs from the transmission to compute which range in the transmission should be engaged. This is accomplished with solenoids that control line pressure, converter lockup, and shift valves. By activating solenoids, the transmission is shifted into the required range.
Your code indicates that shift solenoid C is apparently not performing its required function. This could be for several reasons....
1) The solenoid could be shorted or open.
2) The solenoid could be mechanically stuck.
3) The corresponding valve in the valve body could be sticking,
Access to the solenoids can be gained by removing the side pan from the transmission. For access, you must remove the left side powertrain mount and bracket. There is not a lot of room to work, but you can get to it.
You can check the solenoids for the proper resistance with an ohm meter. If resistance checks OK, you need to identify which solenoid is causing the problem. The solenoid is then easily replaced.
However, if the problem is internal to the valve body, then the valve body will need to be disassembled and repaired. This job does require some special tools, and is a bit beyond the scope of home repairs.
