engine keeps overheating?
1996 FORD TAURUS
139,000 MILES
DORIAN_WINDLEY
I have a 1996 Ford Taurus that keeps over heating it has a new radiator and new water pump but it still continues to over heat what else could be the problem? everything that would cause it to over heat is new what else could it be?
Jan 13, 2012 at 12:04 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
It sounds like you may have a cooling fan that is not working but o be sure these guides will help us find the problem.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Jan 13, 2012 at 12:09 AM
SCVCANDO
  • 6 POSTS
How about the thermostat? Are you getting heat from the heater? If not, the thermostat may not be opening to let the coolant circulate which overheats the engine but not the heater core.
Jan 14, 2012 at 3:18 AM
MIKEMAN124
It started about two days ago, while I am driving, the car temperature starts to rise and stays at the hot side of the thermastat. I will let it sit for awhile and also have to refill the water because when I stop, it all starts to come out the overflow. I start it back up and drive for a little more and it heats back up again.
Aug 25, 2020 at 11:11 AM (Merged)
  • 110,190 POSTS
Have you tried the basics such as changing the thermostat, flushing the cooling system...?
YOUKNOWMYNAME67
  • 25 POSTS
it does sound like a thermo issue. if the thermo is siezed shut it will not open causing the over heating problem and the water pushing itself out the resevoir is just a sign there is a problem delivering the coolant. (siezed thermo)
ROADWARRIOR320
I've changed the themostat, radiator, heater core, temp. sensor, temp. sending unit, upper and lower radiator hoses, & water pump, the coolant is fresh and the right mixture 50/50 and the fans are working properly. It only tends to overheat whlie driving, when in park at idle with A/C on max it will not over heat. Trans. fluid is at the right level. Will changing the trans filter and oil fix the problem? Trans not giving any trouble
Could be air lock -bleed the cooling system
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
TOTO_FORDKUGS
how to drain my coolant reservoir and where is the location of my thermostat?
  • 110,190 POSTS
Hi:
The coolant tank will need removed or sucked out. As far as the t-stat, follow the upper hose to the engine. It will end at the thermostat housing. The t-stat is under the housing. I think the housing is held on by two bolts.
As far as the freeze, make sure you didn't pop any of the freeze plugs. Also, if it froze solid, you may find other problems after it's running again.
ERINFROEHLICH21
Engine Cooling problem
1996 Ford Taurus Automatic
So I have 1996 Ford Taurus that has been having overheating problems for a couple of days, but didn't seem to affect the way it ran. However, yesterday when I was driving home and it started to make a very loud rattling noise whenever the accelerator was pressed and it stalled out. I was able to switch it into park, turn it off and restart it just to have the same thing go on again after a very short and noisy ride. I know it must be some sort of cooling problem, my car is leaking green fluid and one of my friends noticed my fan wasn't working when the engine was running. How much do you think this would cost to fix?
DDANN
The nois you were hearing probably was the fluid boiling First look to see if the front of the radiator is clear of blockage, the front isnt smashed closed, etc if it looks fine then the lack of fan and overheating might have caused a build up of gunk, take it to the carwash and remove the two hoses spray through and watch what comes out, it would be smelly and probably brown If it is caused by overheating then the leak might be on the little metal line that goes from the radiator to the transmission let the car get warm and see if the fluid is leaking out around where it connects to the radiator a new line is pretty cheap. if this doesnt work after 1 or 2 tries try taking it to have the coolant flushed profeshionally. also on my taurus the fan is set by a thermostat and only turns on when the car reaches a temperature of 190 degrees so also check that when it gets hot. It all could be caused by a bad thermostat which could make life a lot easier on you
JUSTDON
  • 155 POSTS
Fan relay has failed.... a Taurus is very sensitive to overheating. I hope that a head gasket and/or intake gasket has not blown due to the overheating.
Never re-statr an overheated engine. I would bet that you need a professional to take a look to rule out further damage to the engine.
BLAZIN24
  • 6 POSTS
Dear BMRFIXIT the engine will overheat unless I have the a/c on. I read some other posts with same problem what I needed to know is the guage on the dash reads right, (I know when engine is getting hot) but the fans don't kick on at all.Could this still be the temp. sensor even though the guage reads right. Thanx for the quick reply last tme. blazin24
Could also be the engine temperature sender
BLAZIN24
  • 6 POSTS
where is the engine temperature sensor ? and approx. how much does one cost ?
Its near the thermostat along with the engine coolant temperature sensor, about $30.00
BLAZIN24
  • 6 POSTS
Hey rasmataz thanx for the quick reply, Im going to try these two possibilities in the next week or so (short on dough right now) but I will let you know as soon as I do. Thanx again , blazin24
OLMJENSEN
my 1996 ford taurus has overheating issues. It can sit and idle forever, and not overheat, but when I start to go somewhere it starts pumping the water out of the reservoir. I have flushed the lines and reservoir, repacedthe thermostat. Any ideas?
CARADIODOC
  • 34,309 POSTS
Have your mechanic check the cooling system for combustion gases. That involves drawing air from the radiator through a glass cylinder with two chambers partially filled with a special dark blue liquid. If the head gaskets are leaking, that fluid will turn bright yellow.
UNSURE
  • 9 POSTS
My engine is overheating and leaking/overflowing from appears to be the reservoir. This maybe a stupid question but for the best service and cost...where would be the place to take it...
1) regular auto shop
2) radiator shop
3) other specialist
Is one better than the other for this kind of problem?
Thanks in advance.
BMRFIXIT
  • 19,053 POSTS
all will be OK
you need auto shop that will diagnose and repair
and I think you may need a head gasket test and repair
so check if they can handle the job 1st
if its mount up to a head gasket
SCORPIONTEARS341973
1996 Ford Taurus 6 cyl Two Wheel Drive Automatic
my heat hand is fluctuating from cold to about 3/4 of the way to hot it does this constantly while driving or idleing
Aug 25, 2020 at 11:12 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello
This could be several things. Air in the system will cause erratic gauge readings. A defective radiator cap will too. A defective sending unit, a defective thermostat. If your cooling fans are not properly working, coming on and off, your water pump may not be moving the coolant and your radiator may be clogged.
All assuming you do have plenty of antifreeze in the system………yes?
Not sure when the last time you had the system open for repairs……..but my suggestion would be to first, ensure the system has the correct amount of coolant, no air in the system, ensure the cooling fans are proper working, replace the radiator cap……then change the sending unit, then the thermostat. Do these one at a time to see what makes the difference.
If you need more assistance then please ensure you provide the exact engine by liter and the 8th digit of your VIN.
TEJINDER SINGH
1996 Ford Taurus 4 cyl Two Wheel Drive Automatic
mY CAR OVER HATS
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
