1995 Ford Taurus Repair Question
Topics covered: Engine, Ignition switch, Fuel pressure.
Asked on September 20, 2010
1995 Ford Taurus
Engine Mechanical problem
1995 Ford Taurus 6 cyl Two Wheel Drive Automatic 173000 miles
Where is the engine control module located?
Answer
Replied on September 20, 2010
Powertrain Control Module (PCM) On top right side of firewall.
is the powertrain control module and engine control module the same
Its the same thing-unless you are referring the ICM ( ignition control module ) as the computer-
i have installed new igintion module car still shuts off as if you turn the key off let it set for about 5 min it will restart what is my next step with out a scanner
Replied on September 21, 2010
Check the fuel pressure to rule out the fuel pump-could also be the ignition switch breaking up when it heats up-
how do you test an ignition switch?
