Fuel pump relay
BODURHAM
  • 1997 FORD TAURUS
Can anyone help me find the fuel pump relay in my car? According to the Chilton's electrical diagram of the car there is one on it, but they fail to mention anything regarding its location. Is the fuel pump relay perhaps inside of the control module?
I have checked the inertia switch, verified gas is not going to the engine by removing the line before the gas filter, replaced the pump to my dismay, and made sure the fuse not broke. I have also checked the fuse box underneath the steering wheel, underneath the hold, and also checked underneath the driver's seat with no luck.
Starting to really dislike Ford at this point.
Thursday, January 12th, 2006 AT 6:28 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
The fuel pump relay is incorporated in the constant control relay module located next to the battery. I would recommend spending the extra money and purchasing it from the dealer instead of the local auto parts store as I learned the hard way.
HEre are some guides to help you test it.
and
Here is its location (below)
Cheers, Ken
Friday, November 3rd, 2017 AT 5:24 PM
MR.SMITH_5
  • 1995 FORD TAURUS
Engine Mechanical problem
1995 Ford Taurus Automatic
I have dicovered that I must replace my Fuel Pump Relay or Regulator but I cannot find where its at. I have an general idea of where it is located which is to the left of the battery somewhere on or around the radiator guard. Please assist me with finding the location of this part because my car is unable to run without it.
Thanks
Friday, November 3rd, 2017 AT 5:25 PM (Merged)
Hi mr.smith_5, Welcome to 2carpros and TY for the donation
Dunno what liter engine but am using a 3.0 liter-the fuel pump relay is integrated with the constant control relay module-see below for location
https://www.2carpros.com/forum/automotive_pictures/12900_ccrm_1.gif
Disconnect battery ground cable, then remove radiator sight shield.
Disconnect electrical connector, then remove module from radiator support.
Reverse procedure to install.
MR.SMITH_5
So basically I have to replace the whole Intergrated relay control module to replace the fuel pump relay correct?
IF the relay has failed, you will need to replace the relay box.
MR.SMITH_5
Ok sir, thanks
I think that was slightly the problem becasue at first no fuel was coming up to the engine. It cranks and seems like it wants to start but it just will not start. I ran out of possible ideas of what the problem could be except the fuel pump, which I do not know where its located at.
WALTER FARROW
  • 1995 FORD TAURUS
Electrical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
Where is the fuel pump relay located
DAVE H
  • 13,383 POSTS
Low Fuel Pump Relay. In engine bay, on center of firewall.
The fuel pump is in the fuel tank
KELSIE
  • 1995 FORD TAURUS
Computer problem
where is the fuel pump relay located at in a 95 ford taurus
Hi kelsie and welcome to 2carpros
Its in the engine bay on center of firewall-sorry no pic available
DRENEAWHITE
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 126,788 MILES
Electrical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 126788 miles
does this car have a fuel pump relay and where is it located
DAVE H
  • 13,383 POSTS
MATTPS2012
  • 1993 FORD TAURUS
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
Where is the Fuel Pump Relay Located?
https://www.2carpros.com/forum/automotive_pictures/12900_fprf_2.jpg
The Fuel Pump Relay is part of the Integrated Control Relay Module, is located at the front of the engine compartment, on the upper radiator support.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
REYALCRAN
  • 1991 FORD TAURUS
Computer problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic
where is the fuel pump relay located for a 1991 ford taurus
Monday, September 16th, 2019 AT 4:26 PM (Merged)
There's no listing for the fuel pump relay try the inertia switch at forward of left rear quarter panel above left wheelwell. Jumper it and see what happens.
TAURUSWHEEL
  • 718 POSTS
It may be located in the ccrm black box, located on top of the radiator, under the sight shield. I don't believe it is serviceable. There are a couple other items in there also, a c relay, fan control relay. Unplug the fuel pump connector to the inertia switch, apply 12 volts to the plug, listen for the fuel pump to turn on to confirm pump is good
TAURUSWHEEL
  • 718 POSTS
On earlier Taurus, the ccrm was originally called the integrated controller module, not sure when they changed names
