1994 Ford Taurus window
1994 FORD TAURUS
ANCHORPASTOR
Electrical problem
1994 Ford Taurus Two Wheel Drive Automatic 189000 miles
The drivers side rear window went down and now will not go up. If I push the switch in the down mode, you hear a motor noise, but it is already down the half way it goes. When you push it to go up there is no noise at all. The main switch on the drivers front door doesn't make it go up or down and there is no noise made from that door when you push it. The drivers door switch that turns off the two rear windows is on. The motor noise only happens when I push the rear door to go down. When I push it to up there is no noise. What is wrong and how or what do I need to do?
Jan 25, 2009 at 6:44 PM
