1994 Ford Taurus trans/gear shifter
1994 FORD TAURUS
125,000 MILES • 6 CYL • FWD • AUTOMATIC
1994FORDTAURUS
Hi, On a 1994 Ford Taurus with a transaxle and AT. The gear shifter is on the column. The shifter will not go into PARK. The car can only be started and shutoff in reverse. Gear selector is very sloppy. The speedometer is not accurate as the needle swings back and forth. Why won't the shifter go into PARK? Why does the car shutoff and start only in REVERSE? Could the trans problem and speedometer problem be related? Thanks Bill
Jan 6, 2010 at 6:18 PM
