2CarPros - Car Questions & Answers
1991 Ford Taurus Repair Question
Topics covered: Wheel, Brakes, Abs.
Asked on June 15, 2009
1991 Ford Taurus master cylinder
Brakes problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic
Hi_I had a brake pedal seeping down so replaced rear wheel cylinders (drum) and then the master cyl.-after bleeding the system the pedal feels good and firm but after starting engine pedal goes down even worse than before-tried a second m. cyl. and had same results.This car is not equipped with ABS or at least I don't think so (has no wires or sprockets at the wheels) Have re-bled the system several times-have good flow at all wheels.The car has decent brakes on the road but still goes to the floor after a few seconds--Any ideas ??? Thanks...Dennis
PS-1991 Taurus GL w 3.0
Avatar Asked by dbullin
Answer
Replied on June 18, 2009
By all accounts, your problem should have been fixed. Suspect a leak in a brake line. Does the fluid level remain at the proper level? These cars have had some issues with brake lines rusting through in the area above the gas tank.
Tiny Answered by jgarofalo
1 question asked
