2CarPros - Car Questions & Answers
1989 Ford Taurus Repair Question
Topics covered: Radiator, Engine, Pressure test.
Asked on October 26, 2008
1989 Ford Taurus major coolant leak
Engine Cooling problem
1989 Ford Taurus 6 cyl Two Wheel Drive Manual 92000 miles
its a for taurus station wagon its leaking a lot of antifreeze from the front of the car it coming thru the bottom hitting the ground i filled the resevoir and radiator the resevoir is emptying very rapidly like every two days whay are some of the likely causes of this problem
Avatar Asked by makenziepapa
Answer
Replied on October 26, 2008
Check water pump , hoses and check radiator
pressure test needed to determine the location and the reason of the leak
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Tiny Answered by BMRFIXIT (expert)
19,736 answers provided
