1989 Ford Taurus Repair Question
Asked on June 13, 2009
1989 Ford Taurus engine overheats
Engine Performance problem
1989 Ford Taurus 6 cyl Front Wheel Drive Manual 135000 miles
My mechanics can't seem to find out why my Taurus is overheating. Cooling system has been flushed.
Answer
Replied on June 13, 2009
check 4 any colapsed hoses during engine revs 2000 3000 rpms, 4 about 2/3 min, check temp of raditor from top to bottom side to side at time of higher temp, 2 c if there is a temp change. if is radiator is stopped up. water pump may npt be spining coolant thu. make sure bleeding process is correct , to bleed air out of the system. take a funnel put on radiator 2 have coolant higher than the engine. does it run hot in city or highway driving ? email sr_0009@yahoo.com
