Mechanics
POWER WINDOW PROBLEM
1998 Ford Station Wagon
Subject: Ford Power Window Problem.
1998 Ford Taurus Wagon.
The driver's-side power window will not go up.
I have had this problem before and slammed the door shut several times and it worked, but not now.
Possible Problems.
(1) Intermittent switch?
(2) Loose connection?
(3) Motor?
(4) Other?
How to diagnose?
How to repair?
Need diagram of door cover with removal instructions.
Thanks, Chuck Gallo
ChuckGallo
August 16, 2009.
When it isn't working, you need to first remove the door panel and check to see if there is power to the motor. If there is, replace the motor. If there is no power, check to see if there is power to the switch. If no power, check the wiring harness between the door and the door frame?
