2CarPros - Car Questions & Answers
1989 Ford Station Wagon Repair Question
Topics covered: Engine, Vacuum check valve, Wheel.
Asked on August 24, 2010
Air blows warm when engine under sl
Air Conditioning problem
1989 Ford Station Wagon V8 Two Wheel Drive Automatic 106789 miles
My A/C system will only work well at idle condition. When the engine is even under the slightest load; the fan shuts off and the air becomes warm. Only after returning to idle or unloaded conditions does the system return to normal. I've checked the vacuum tank ( "coffee can") and that holds good vacuum; I was thinking the vacuum check valve may be bad but I wouldn't think that would effect fan speed. Any thoughts??
Avatar Asked by Henry Ackell
Answer
Replied on November 5, 2010
Does the fan stop running or does the air flow direction change?
Tiny Answered by Jacobandnickolas (expert)
57,474 answers provided
