Ford Ranger Repair Question
Topics covered: Fuse, Turn signals, Panel.
Asked on August 23, 2006
Turn signals and flasher help needed.
1997 Ford Ranger 85,000 miles-My turn signals went out and I replaced the blue relay box(which I was told is the flasher for the turn signals) and still no luck. Both side still do not work.[/b]
Answer
Replied on August 23, 2006
When you say out, do you mean they dont light at all, or they light but dont flash?
There are 2 fuses in the I/P fuse panel that supply power. A 10amp and a 15amp fuse. That power goes thru the Electronic Flasher, and then to the Multi-function switch, then to the lights. If the fuses are good, and the electronic flasher is good, then I would suspect the switch or a wiring break as the problem.
