EGR Valve Location
2002 FORD RANGER
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
RBOLISH
I have a engine shimmy/bump/shake at idle. I got a number 5 misfire and replaced the plugs, wires and ignition coil but the still have the problem. I've looked to replace to EGR valve but cannot find it. Checked other forums and some have said there isn't one and some said there is. While others said to replace the DFPE. Need some guidance on this.
Nov 6, 2010 at 12:48 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,346 POSTS
Hey RBOLISH,
The EGR valve is located bolted to the intake manifold with a vacuum line going to it. Here is what it looks like, Please let me know if you need anything else to get the problem fixed. There are two styles. (Below). Please let us know what happens.
Dec 16, 2016 at 3:13 PM
WCHOLT
2001 Ford Ranger 4 cyl Two Wheel Drive Manual 180000 miles
Where is the EGR valve located on a 2001 Ford Ranger 2.3L ?
Dec 16, 2016 at 3:14 PM (Merged)
WCHOLT
I don't know what the code was. Auto Zone did the free computer test to see why the check engine light was on and the results were to have to EGR Valve replaced. That is all I know.
BMRFIXIT
  • 19,053 POSTS
See what the most common is the DPFE sensor
on the EGR system and replacing the valve will not help
if you can try and get the code again I can send you the test step to it
HMAC300
  • 48,601 POSTS
we don't have a good picture of that at all only the valves there are a few different types.with something that old you'll have ot find another vehicle with same engine unless I can find something on the ford site. see pic and it gives a few ideas where it may be located. or at base of carb which if it were there would have aplate to it.
COOL2121
i need to check the timing, i can't find the marks on the crankshaft, and their is some sensor to disable where is this located at?
also where is the egr valve located on my trunk
can you reset the check engine light? i fix the problem with the maps sensor and clean the throttle body out codes 159, 158, 157 were coming up on scanner thank you
98RANGERXLT
  • 301 POSTS
Yes you can clear the codes on the computer you can go to autozone and theyll check it for free and clear the codes.
Dec 16, 2016 at 3:15 PM (Merged)
RUDPRO
  • 224 POSTS
I don't have the repair book for your vehicle but I did some checking online and I don't think your timing is adjustable. Check the VECI sticker under your hood. It should tell you the degrees of timing, if it's adjustable. If it doesn't have it, it's not adjustable.
The EGR valve is on the drivers side of the engine, with the tube going into the intake manifold.
Your computer is an OBDI. To reset it, disconnect the negative battery cable for a half-hour.
  • 5 POSTS
Engine Mechanical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic 13000 miles
just wanted to where the egr valve is located on 4.0 v-6 ohv.the ven no.is x it has no cmp sensor.thanks for your reply on my last post.it was very helpful
AAUSTIN68
Can you tell me the location of egr valve? I am getting a p0401 code?
  • 110,190 POSTS
Should be on the intake
