2003 Ford Ranger
Noises problem
2003 Ford Ranger 6 cyl Four Wheel Drive Automatic 84687 miles
The 2003 Ford Ranger is sitting in my garage and it is clicking. The engine is not on, the key is not in the ignition, and this truck has been clicking for 4 days. I think it is a relay switch, but where do I start?
Jani rae
November 28, 2009.
WHat part of the vehicle is it coming from? Also, have you tried pulling fuses one at a time to see which one makes the noise stop?
The noise is coming from the dash. The noise does not go away unless I take the battery cable off. I have not tried replacing fuses, simply because I have not had time to start messing with the truck. I do believe it is a relay switch and maybe even connected to the anti-theft system. Thank you for your answer, and I will try the fuses.
Jani rae
Dec 2, 2009.
