2CarPros - Car Questions & Answers
2002 Ford Ranger Repair Question
Topics covered: Engine, Check engine light, Compression.
Asked on December 29, 2009
2002 Ford Ranger misfire
Engine Mechanical problem
2002 Ford Ranger 6 cyl Two Wheel Drive Manual 130000 miles
have 03 ranger 3.0 that is misfiring. replaced coil and heads, had valve job done, checked compression all good still misfirers! what else could be wrong? thanks
Avatar Asked by sessions10
Answer
Replied on December 29, 2009
Is a code set?
Tiny Answered by Docfixit (expert)
18,433 answers provided
What does that mean?
Tiny Response from sessions10
1 question asked
Check engine light on?
Yes and its flashing
1 question asked
Go to an Auto Zone have codes pulled then post
Codes p0301, p0303 and p0305 which is a misfire in cylinders 1,3 and 5, and they said something bout the emissions.
1 question asked
Was the same engine miss there before heads r&r? Has fuel injectors been checked on those cylinders? is miss at idle and under acceleration? Have vaccum leaks been checked ?
It was not missing before. Could it be something electrical?
1 question asked
The cylindes that are effected indicate an intake leak. Check injector connections if good . Consider pulling top intake and give close look at gasket seal.
