Mechanics
NO TURN SIGNALS
1999 Ford Ranger
Electrical problem
1999 Ford Ranger 6 cyl Four Wheel Drive Manual 199000 miles
Currently I don't have any turn signals, though I do have Hazard signals. All four lamps flash with the hazards on so I know the lamps are good, but when I turn on the right or left turn signal I got nothing. No signals on the dasboard, no relay noise nothing at all. I did replace the relay according to Haynes it jst one relay for both hazards and signaling. I also check the fuse.
Any other ideas I could try?
Frusterated Jim
James Arnett
December 29, 2009.
If flasher unit (located behind left side of dash) was tested OK then suspect faulty multifunction (turn signal) switch.
Bluelightnin6
Dec 29, 2009.
AD
