Mechanics
CAMSHAFT SENSOR
1999 Ford Ranger
Engine Performance problem
1999 Ford Ranger 6 cyl Two Wheel Drive Automatic 95000 miles
i just replace my camshaft sensor when I was doing that I notice that it just was spending around. Is there I screw or a pin that goes in it or something?
Jlynch777
September 21, 2009.
Hi jlynch777,
Thank you for the donation.
Sorry I am not able to grasp what is meant by the part spending around. Can you please elaborate on which part is " spining "?
What is the reason for replacing the part? Is it a trouble code P0340?
KHLow2008
Sep 22, 2009.
The check engine light was on and it told me to replace the camshaft position sensor. When I was doing the I put the the new one on and it would just spin. If you can call me.
Jlynch777
Sep 22, 2009.
There are supposed to be 2 screws to hold the sensor in position.
http://www.2carpros.com/forum/automotive_pictures/192750_CamSensor99RangerFig03_1.jpg
KHLow2008
Sep 23, 2009.
I did that. The sensor and the thing that the sensor gos on spins to.
What is the hole for under where the wires hook up at? Is there a pin or a screw go in there so it wount spin?
Jlynch777
Sep 23, 2009.
The sensor is plugged into housing and can be turned but not freely. Check if the seal is good/correct. There are no pins or lock as explained in the shop manual.
The only advice offered was to note the wire connector position before removal of sensor.
AD
KHLow2008
Sep 24, 2009.
AD
