How do you remove something that is stuck inside your ignition causing your key to not completely go in?
1999 FORD RANGER
UK_FAN11
The object appears to be a small and medal and its stopping the key from going completely in the ignition.
Nov 30, 2011 at 2:12 AM
BILLYMAC
  • CAR REPAIR CONTRIBUTOR
  • 2,204 POSTS
this may be a part of the tumbler.unless you suspect vandalism.
you can get a small pick set from your local auto store and try to remove it or try to position it back into the cylinder where it came from. if this don't work unfortunately ,you will have to replace the cylinder. Here are instructions in the diagrams below to help you. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 30, 2011 at 2:18 AM
CRUISER1221
I just picked up a used ford ranger. When I test drove it, I noticed the ignition was stuck for a second, then no problem. Well, i bought the truck, drove it for a day and now when i put the key in the ignition, it won't turn at all.....it's like it's hitting a brick wall. It goes into the ignition, but I don't hear a "click" you usually do. What do I need to do to fix this?? I want to drive my new truck, but as it stands, I have a cherry 1996 garage decoration. How do I remove the ignition?? the key just won't budge at all. thanks for any help.
Aug 12, 2019 at 6:40 PM (Merged)
  • 110,190 POSTS
First, it could be a couple things. If I had to guess, I would say the tumbler, the part the key fits into. Try spraying a lubericant into the thmbler, then run the key in and out several times. Try this a few times to see if it loostens things. Some people use WD40 and it works, but they do make a lubericant made just for tumblers.
Try this before replacing the tumbler. I can't recall if a 1996 had a coded key. If it does, it's a dealer job because the computer will need to be adjusted to accept the new code from a new key. Not cheap to do.
Try it and let me know if it helps.
CRUISER1221
thanks, I had already tried that, nothing. it's not a coded key, so I just removed the ignition and bought another for o-reilly for $22. Now I'm going to take out my door locks and have them made to match the ignition key.
thanks again.
