Mechanics
FUEL FILTER REPLACE
1995 Ford Ranger
Engine Mechanical problem
1995 Ford Ranger 6 cyl Front Wheel Drive Automatic 140000 miles
JUST REPLACED MY FUEL FILTER AND SPARK PLUGS. TRUCK WILL NOT START. DID I MISS SOMETHING? TRUCK WAS ON EMPTY. COULD THIS BE PART OF THE PROBLEM? (SINCE REPLACING THE FUEL FILTER I ADDED 2 GALLONS)
Wezleyz69
August 28, 2010.
Need to cycle some fuel into system since you ran it out. To do this, turn the key on without cranking. Listen for the fuel pump to buzz. It should run 2 or 3 seconds. When it turns off, turn key to off than turn back on again. Do this several times to get the system primed back up and then crank engine to see if it starts.
Bluelightnin6
Aug 28, 2010.
AD
