2CarPros - Car Questions & Answers
1995 Ford Ranger Repair Question
Topics covered: Rim, Engine, Sensor.
Asked on July 7, 2008
1995 Ford Ranger Check Engine Light Code: P0172
I just bought this truck for work but I am having a problem figuring out this check engine light
The engine runs good, slightly rough idle and I don't think it is getting the best mileage. I also think it is quite low on power. I cleaned the MAF thinking this may be the cause but did not seem to change anything. I cleaned it with an electrical cleaner that does not leave any residue.
Also, once I reset the MIL code, it seems to reappear after about 50 miles but it will be quicker if I'm using my a/c, which cycles too much (probably low on refrigerant)
I'm not one to throw a lot of money at a vehicle with this many miles so hopefully you can help me. I don't like to replace parts until I'm sure they are bad.
The code I'm pulling is P0712 - System too rich (Bank 1)
Here is the info I got from the scanner:
I/M monitors:
Misfire Mon: OK
Fuel Sys Mon: OK
Comp Component: OK
Catalyst Mon: INC
HTD Catalyst: N/A
Evap System Mon: N/A
Sec Air System: N/A
A/C Refrig Mon: OK
Oxygen Sens Mon: INC
Oxygen Sens HTR: INC
EGR System Mon: OK
Freeze Dat
Engine RPM: 1576
Load Value: 78.0%
Coolant Temp: 188f
Short Term Fuel Trim 1: -5.1%
Long Term Fuel Trim 1: -16.1%
Short Term Fuel Trim 2: -5.1%
Long Term Fuel Trim 2: -16.1%
Short Term Fuel Trim 3: 53.9%
Long Term Fuel Trim 3: 47.6%
Short Term Fuel Trim 4: 59.3%
Speed: 32mph
Fuel System 1: CLSD
Fuel System 2: N/A
Any help will be greatly appreciated!!!
Avatar Asked by 1sandiegan
Answer
Replied on July 7, 2008
P0172
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Tiny Answered by rasmataz
68 questions asked
I removed the vacuum hose to see if there was any fuel in it but it was dry.
Also, what do you think would be the most likely cause? I looked at the O2 sensors and they actually look pretty new.
Thanks for your help!
Tiny Response from 1sandiegan
1 question asked
You need a scantool to finger the oxygen sensor/s by viewing the switching activity/fuel trimmings-Your fuel mix is on the rich side-
68 questions asked
