Whats wrong with my engine it misfires?
SHESHE51
  • 1994 FORD RANGER
  • 4 CYL
  • 118 MILES
1994 ford ranger 2.3 liter engine misses and stalls after warm up raw gas smell off exhaust.
Wednesday, July 6th, 2011 AT 7:27 PM
This guide will help us
Wednesday, July 6th, 2011 AT 8:18 PM
PTHOMPSON
  • 1994 FORD RANGER
Hi Guys. I'm having slight trouble with my '94 3.0V6 Ranger, approx 60K miles. When the engine is cold, then truck runs fine but once the engine warms up, the truck misfires constantly. I've done serveral part replacements; new plugs, leads, cap and rotor, even the coil. My mechanic thinks it could be the distributor itself. Any ideas? By the way, this only started to happen when I replaced the plugs and wires. I checked and rechecked the wires and plugs. When my mechanic checked the wires and plugs he mentioned the misfire wasn't from any specific plug, more sporadic.
Thanks again, Phil
Wednesday, July 29th, 2020 AT 11:24 AM (Merged)
PEPPERMRJ
  • 1,158 POSTS
Random misfires that jump around from one cylinder to another have an underlying cause that is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Did you try putting back the old plugs and wires?
Good hunting and let us know. :)
PTHOMPSON
Thanks for the info. I replaced the EGR valve, I'll have a play with the truck this weekend.
PTHOMPSON
Well, here's the answer to the fix. However, before I tell you, there's a leason to be learned. Never listen to your friends that say they're "car savvy". Always go with your gut instinct. My gut instinct kept telling me that the new spark plugs I had just put in were faulty. My mate kept telling me there's no chance that would happen. Well, the ceramic was cracked on one of the spark plugs which made the car buck like a bull when it was warm. ALWAYS CHECK YOUR PLUGS. EVEN IF THEY'RE NEW! Thanks for all the help.
PEPPERMRJ
  • 1,158 POSTS
Thanxs for the update. Good advice. I have heard of that more than once. Not very common but a real PITA. :D
JOHNNY G.JR
  • 320 POSTS
Thanks for the reply
VICKIAYALA
  • 22 POSTS
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 248,000 MILES
94 Ford Ranger 2.3 stnd 2wd, runs fine when it first starts, gets down the road and begins to***** and backfire. If I start out slow and down shift before its time to, it will go, but if I give it too much gas at first it hesitates, ****** and backfires. It feels like its going to beat me to death. It loses power as I climb up a hill, if down shilt and floor it it starts to clear out the***** and backfire checked all fuel cdomponents, they rare ok. I was told it was an ignition problem. I charged spark plugs, dual coils, ignition position moduel. I even changed the 02sensor before the cat, cleaned the EGR, has good vaccum and I'm stumped. Do you have any suggestions of what I might check next. I'm stuck! Vicki
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it and keep testing
VICKIAYALA
  • 22 POSTS
I replaced my alternator in Jan. When I unplugged and drove it unplugged it ran like nothing was wrong with it. Plug it back in and it****** and backfires like crazy. Still trying to figure out whats wrong?
  • 1994 FORD RANGER
  • 6 CYL
  • MANUAL
  • 200,000 MILES
I can't get the old throwout bearing off of the slave cylinder. I tried the methods in the book: Twisting it to put pressure against the spring, then pushing down on the spring to release it. Nothing works. I don't want to break the slave cylinder because I want to reuse it. How do I get the throwout bearing off?
TIG
I just replaced mine. I figured it out from your comments, thanks for giving me a clue.
I removed the slave cylinder so I could get a good look at it. I turned the bearing counter clockwise until it stopped. Then I pulled and twisted CCW sharply. It popped off.
I know this is late for you but maybe it will help the next guy.
Cheers
KBHATIA007
  • 12 POSTS
  • 1994 FORD RANGER
  • 6 CYL
  • 262,000 MILES
After a long dedicated 14 years, thhr ranger is beginning to act up. Have replaced fuel pump, fuel filter, spark plugs wires etc. But the engine seems to be missing firing on a cylinder when idling. When under power, it seems that the truck is going to buckle over and shudders very badly. The fuel pressure is good @45psi. The transmission has about 160000 on it. It was running ok till I decided to do some PM on it and has never been like before. Every mechanic has pointed in every different direction. The truck passed emissions with flying colors two weeks ago when the problem was intermittent. Now it is continuous. Compression in cylinder 3 is 75psi(as per the repair shop). What should I do next and what is the problem?
Thanks for your help.
BLACKOP555
  • 10,371 POSTS
260,000 miles is phenominal.
It may be time for a engine overhaul, sounds like the rings are wearing, how did a wet compression test handle? The pressure go up significantly?
75 is pretty low and will definetely make a missfire very noticble at low speeds.
KBHATIA007
  • 12 POSTS
Will be doing a wet test in a couple of days, but everybody wants me to swap the engine out, which I am very hesitant to do. Want to rebuild the head and the valves if that sounds like it will solve the problem. If the pressure comes up with the wet test then only I will swap the engine.(Indicating bad rings). We will know pretty soon.
BLACKOP555
  • 10,371 POSTS
Rebuilding the heads as you suggest could work if the rings arent worn.
Might be time to checking the bearings also. The rings could be worn, the cylinders are probably worn.
KBHATIA007
  • 12 POSTS
Thanks blackop555 :-))
We will know better tomorrow after the wet test. I think that will decide if I need to swap the engine of work the valves and the heads. I really do appreciate your input. Let us wait and seee.
MOREFLYNG
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 187,000 MILES
My Ranger is not firing on cylinders 1 and 4 on the rear coil pack and has a rough idle w/check engine light. Pulled the code as multiple misfire. I replaced the coil but it had no affect. I verified no spark on 1 and 4 by simply using a timing light and checking all 8 plug wires on both packs. Yes 8, as it has 2 plugs per cylinder. I also pulled the plug wires off the coil with no arc on said cylinders. I want to know where I should be looking to solve this issue. ECU, sensor? Thank you.
BLACKOP555
  • 10,371 POSTS
No problem, I hope the best cheapest way for you!
If you need further assistance im here to help!
Wednesday, July 29th, 2020 AT 11:25 AM (Merged)
Check the crankshaft position sensor if okay -its coming from the ECU
